Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 10th June 2007
dela06 dela06 is offline
Sportster/Buell Year: 03
dela06 is an unknown quantity at this point
Question Engine turns over but won't start
I am brand new to this and I'm a new rider, however, I don't think the problem is as straightforward as it seems. I went about 5 miles to the store without any problems. Got back on the road to come home the bike immediately stalled without warning. I pulled it over and tried firing it back up but it wouldn't go -turned over but wouldn't start. I ended up leaving it sit there for a couple of hours and when I returned it started back up without a problem. After driving maybe a mile it again stalled without warning. Again, after leaving it sit for a little while it started back up, only to die a few miles further down the road. This time it started back up in the time it took the light to turn green.
It's an 03 Sportster with a screamin eagle carb and exhaust. I checked the spark plugs and they look great. Pulled off the air cleaner - no better. It's died while switched to both main and reserve. Suspected bad gas but I ran fine on 2 gallons of it last time I rode. Is there a fuel filter or screen that might be clogged? An electrical problem? Thanks.
Old 10th June 2007
DJJSR's Avatar
DJJSR DJJSR is offline
Other Motorcycle Model: Suzuki S83 1400
DJJSR is on a distinguished roadDJJSR is on a distinguished road
Yes, there's a screen up in the tank above your petcock. It comes out by removing the petcock. There's also a vacuum diaphram in the petcock that only allows fuel to flow when the engine is running. They go bad, and it can be replaced with a non-vacuum petcock.
Don
Old 10th June 2007
KC_Sporty_Gal's Avatar
KC_Sporty_Gal KC_Sporty_Gal is offline
Sportster/Buell Model: XL883C (1235 Conv)
Sportster/Buell Model #2: XL883R
KC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to all
Also check to make sure your jets in the carb aren't getting clogged. Has it sat around alot or anything?
Erica in KC (Red)
"Ruth" '05 XL883C -> 1212 -> 1235 (don't ask) - Pearl Yellow
Progressive Fork Springs, Progressive 412s w/ heavy duty springs, 883 -> 1200 NRHS conversion (at 1235 Now), Daytona Twin Tec Ignition, Hurricane AC
Old 10th June 2007
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Check the vacum line to the petcock as it may be collapsing on itself and shutting off the fuel supply to the carb. Those little rubber hose's over time tend to flatten themselves out and close off the vacum to the fuel supply leaving you stranded on the side of the road, but amazingly work after several hours of sitting.
RTFS
Ride That F'N Sportster!!
Old 10th June 2007
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Recharge and check the battery....
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 10th June 2007
hawk mechanic's Avatar
hawk mechanic hawk mechanic is offline
Sportster/Buell Model: XR1200
Sportster/Buell Year: 09
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 74
hawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nicehawk mechanic is just really nice
Check fuel line coming off of the petcock to the carb as well. Mine had a kink in it and was not letting gas get to the carb. It may not be the problem, but if it is, it's an easy fix.
Joe
'09 XR1200, '74 Ironhead
Old 10th June 2007
and
Old 11th June 2007
Thanks for the responses. The longest it's been sitting is a week and the battery is good. I haven't looked at the jets yet. No kink in the line from the petcock to the carb. I've got to get a syphon and then I can check the rest.
(I also reread the original post - very confusing. Thanks for bearing with it)
Old 11th June 2007
geraldxlch's Avatar
geraldxlch geraldxlch is offline
Sportster/Buell Model #2: 883 Custom
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 1200 xlc in flyrite frame
Other Motorcycle Year: 2002
geraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the roughgeraldxlch is a jewel in the rough
Check with fuel cap loosened, it may not be venting.
Old 11th June 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
I believe you have a bad ignition module inside the cam cover. When it heats up, it fails. When it sits and cools off a little bit, you have spark again.
You need to check for spark when it cranks but won't start. Carry a set of spark plugs with you. When it dies, crank it over to see if it starts. If it does not, then pull one plug wire and insert a new plug in it. Touch the plug to the cylinder head or motor mount and crank the bike over. Hold from the spark plug boot not the spark plug shell in case it DOES have spark. If it sparks, you're going to get a good shock. If you crank it over and you don't see any spark, then you have an ignition problem, and my guess, since it's 1998 - 2003, is that your ignition module failed.
Related:
http://www.xlforum.net/vbportal/foru...?postid=757254
http://www.xlforum.net/vbportal/foru...ad.php?t=53836
http://www.xlforum.net/vbportal/foru...ad.php?t=58797
My $.02
--Chris
