Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 30th November 2009
FOB FOB is offline
Sportster/Buell Model: XB12R
FOB is an unknown quantity at this point
Default Xb 3rd Gear "jumping"
Hi Lads,
I have a problem with my tranny that I haven't been able to find an answer to on my regular Buell Forum - Buells Downunder - in Australia.
Seems like it might not be such a common problem. Bike has just over 25,000miles.
I originally thought I had an intermittent slip in the clutch, but after replacing with a Barnett the problem is still there.
Symptoms:
1. Momentary increase in revs & a physical surge.
2. Only happens in 3rd gear (It has now deteriorated enough after doing the clutch that I can get it to "jump" at will).
3. Only happens after using engine braking & then accelerating.
My guess is that it is the drive dogs on the gears are worn or the selector fork bent.
Any other ideas? Not looking forward to splitting the cases.
Regards,
FOB (Fool Ona Buell)
ReddTigger's Avatar
most likely it's the 3rd gear countershaft. It's a typically common enough problem.. Mostly on sportster's it's 1st and 3rd, but I've heard just 3rd going out..
Unfortunatly you're going to have to dive into the transmission to find out whats the problem..
States I've Ridden in
71.3 hp 70.8 tq
FOB FOB is offline
Thanks Redd
I shall let you know the outcome.
Old 12th April 2011
FOB FOB is offline
Sorry for the delay in reporting back...the problem ended up being the shifter forks wearing. I replaced all the associated gears though, just to be safe.
