0 Sportster or Street Bob
Last Post: RKN
0 Drive Chain Adjustment
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
Old 16th June 2007
OutlawTexan67's Avatar
OutlawTexan67 OutlawTexan67 is offline
Other Motorcycle Model: FXDBi Street Bob
Other Motorcycle Year: 2007
OutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura about
Default Took the Ironhead out for 1st test run!!!!
Well I got the Ironhead done with the exception of the paint job.Gotta wait on that till some funds come in and the 'ol lady quits bitchin'about how much $ I'm spending on it.I took her for a test ride and she runs great no oil leaks just runs like a bat out of hell!!!!But I do have 1 problem I am running drag bars with pull back risers and the original throttle cable is the right length but where it comes out of the handlebars the metal tube hits my tank .I bent it so that it is off the tank but to tell you the truth it looks like sh*t does anyone know how I can solve this prob?Is there a cable that I can run that the metal tube is shorter?
Ain't No Head Like an Ironhead !!!!!!!
Chris
http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=13392 My Gallery
http://outlaws-iguana-ranch.com Outlaws Website
http://i258.photobucket.com/albums/hh266/OutlawTexan67/My%20Ironhead/Gifs/BigRotatingSkull.gif "Ironhead Mafia" European Chapter
Old 16th June 2007
RcRacer's Avatar
RcRacer RcRacer is offline
Sportster/Buell Year: 1981
RcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura about
On my '81, the tubes swivel. The cables are clamped at the steering neck. When the bars are turned to the right, the cables swivel away from the tank.
Does it swivel on yours?
Old 16th June 2007
hoosier xlc's Avatar
hoosier xlc hoosier xlc is offline
Bike Builder
Sportster/Buell Model: This & That
hoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to all
Can't really answer your ?, but being a Shovelhead rider, I can say good job man and at least nothing fell off!
Hooty
Hoot
Old 16th June 2007
Yeah it swivels but when I turn the bars all the way to the right I only have about 1.5 inches clearance and exactly where you can adjust the cable is where it hits my tank.
Old 16th June 2007
Hooty
Not yet but I did go through about 3/4 bottle of blue loctit on the Ironhead.Hopefully everything stays on!!
Old 16th June 2007
Bike Builder
Can ya find a rubber sleeve to go over the metal tube, like on the clutch cable adjuster on an evo to protect it when it hits the tank? Wider bars would definately solve your prob or another 1" on the risers, but that would take some more cash ya don't wanna spend.
Oh yeah, loctite is your friend!
Hooty
Old 16th June 2007
I like the bars the way they are its just this damn cable that is givin' me problems I guess I will have to look around online and see what I can find or maybe fabricate some thing at work that will work.
Old 16th June 2007
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
with some care you can shorten the housing your self
pull the cable out far enuff so ya don't cut it ( carefully tape the end so it don't unravel ) then hit it with a cutoff wheel , deburr the inside and slide the cable back out
measure twice and cut once
"lord of the Night Lite"
thank god for darwin ;)
Old 16th June 2007
I was just thinking about that route and it seems like that will probably be the answer.Thanks!!!!
Old 16th June 2007
flathead45's Avatar
I do it all the time at work when replacing liners on my welder
first rides are the best in the world , I got two on my 72 first was when I bought it and had the tranny rebuilt and second was when I got the topend rebuilt
might just have to take apart just so I can build it again (wooo hooo)
