Last Post: Crosshairs
0 Need advice
Last Post: Krjrcustom1
Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Old 6th December 2009
dukcarvr dukcarvr is offline
Sportster/Buell Model: xl trike 883>1200
Sportster/Buell Model #2: xl bobber project 883>120
Sportster/Buell Year #2: 1993
Other Motorcycle Model: E Glide Classic 95"
dukcarvr is an unknown quantity at this point
Default Curved fender struts hard to work with
Guys ,I need some suggestions/pics on how to work with the curved fender struts on a 1993 sporty! I have cut the bottom out of a "05" 4.5 gal.tank and rewelded it to fit the back bone on the rigid ( and moved the bung & vent tube) Fabbed-up a springer seat pan and an alum. cover plate to hide the electricts under the seat. Chopped and slamed front fender , got 3 degree rake cups on order as well as sparto tail light. So now i want to chop the fender but those dam curved struts are holding me back . Welding & filling holes on the steel fender is not a problem, but working with the alum. struts would be a problem . I'm wondering if struts off of a later model might be modified to work? Thanks in advance for your input.
Mine 05 Glide Classic 95"
Hers 06 Xl Trike 73"
Project 93 xl bobber 51"
SIZE MATTERS
slumchop slumchop is offline
Sportster/Buell Model: 883 xlh
Sportster/Buell Year: 1990
slumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura aboutslumchop has a spectacular aura about
having the same issue as you, I think i may just use the ones I have as a template and machine steel straight ones.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
I think that is what I would do. Seems that in the long run it would be much more simple and easier.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
