Last Post: gravydog
0 1972 tank fitment
Last Post: 72 Ironhead XLH
Last Post: Airbozo
Last Post: nibroc
0 going tubeless in pretubeless 9 spoke mags
0 Help me with gas cap...
0 Sportster or Street Bob
Last Post: joes95bobber
0 1977 xlch starter issues
Last Post: russzx6
0 Primary Oil INSANITY!
0 Lowell, MA weekly moto night (Tuesdays)
Last Post: tvon
0 Blues & Brews 2018
Last Post: tvon
Old 13th December 2009
blacknblue2002's Avatar
blacknblue2002 blacknblue2002 is offline
Sportster/Buell Model: 883N (Iron)
blacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura aboutblacknblue2002 has a spectacular aura about
Default How to fill fluid back in behind Derby?
Just swapped out my derby cover for one of the 'dark custom' ones....of course fluid poured out of when I removed the old cover. I haven't invested in a manual yet (Christmas list item), so how can I refill this area? and should I use oil, Trans Fluid, or some combo?
sorry for the newbie post but I searched and turned up too many results to sort through.
2010 IRON 883N: V&H Comp Pipes, Mastertune kit, Drag Bars, Tank Lift/Wire Tuck, Solo Bag, Bare-Bones Solo Seat, Tinted Turn Signal lenses, and more to come soon
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
With a funnel and taking off the little access door just left and above the derby cover..also having a good FM on hand will also point ya in the right direction
RTFS
Ride That F'N Sportster!!
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
With the bike upright, you want the fluid (Syn 3 or Sport Trans) to just cover the teeth at the bottom of the clutch.
You don't need to add it through the primary chain inspection cover (the small access plate mentioned by Xllent01), you can add it through the Derby Cover. If you add it through the Primary inspection cover access, you won't be able to see when the level is correct.
Be carefull to not over fill or under fill it.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
xllent01's Avatar
You can do it either way..which ever is easier..just prefer the inspection cover cause it's alot less messy, and a whole lot faster
Lenster's Avatar
Yes, it's a bitch to pour it into the derby cover opening. You just can't see the level of the fluid if you don't have the derby cover off.
xllent01's Avatar
Sure you can..just dump it out and put a fresh quart in..easy squeezy..lemon..pleasy
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The Parts Catalog is very helpful too. Gives exploded views of all the sub systems.
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
also a note book or three ring binder....write down date, mileage and what you have done. this will prove invaluable in the future.
Denny
Teehaml's Avatar
Teehaml Teehaml is offline
Sportster/Buell Model: XL1200C (Traded in)
Other Motorcycle Model: Yamaha FJR1300A
Other Motorcycle Year: 2014
Teehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond reputeTeehaml has a reputation beyond repute
Yea... I do the derby cover. I like to see what's happening.
Tom...
themac5150 themac5150 is offline
Sportster/Buell Model: 883 Iron
themac5150 is on a distinguished roadthemac5150 is on a distinguished road
Do you have the owners manual? It's in there...
