Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Old 13th December 2009
Burgester72's Avatar
Burgester72 Burgester72 is offline
Burgester72 is an unknown quantity at this point
Default Help!! - 2008 Nightster Issue
So it's been about 2 weeks since I started it up. It started like a charm as usual and I let it idle for about 40 minutes as I was talking to a friend. Longer idle time than usual by about 35 minutes as the time got away from me while visiting...I have read that Harley's go through a test at the factory where they idle for a long period of time under very hot conditions in regards to outside weather temperature. In the back of my mind I kept thinking that it's ok for it to idle a bit because they get tested like this in the factory and it's no problem for a Harley to idle...
So when I put the bike in first gear and began to take off it "knocked" and I pulled the clutch in. I did this 3 more times and got worried and shut the bike off.
The bike was very "HOT" at this point and even smelled hot. Hotter than I have ever seen the bike.
When I went to start the bike it knocked, caughed and didn't want to start. I tried to start it about 3 times and gave up. The bike was so hot I eventually pulled it out into the windy parking lot and let mother nature cool it down. Thankfully there was a good head wind and the bike cooled down quickly.
It started up "after the cool down" and made the worst knocking sound. I shut it off as quick as I heard the knocking sound and was pretty upset that something bad wrong was happening inside the engine.
I let it sit and cool way down for about 15 minutes.
I hit the start button again and the knocking sound was gone, bike started right up, I rode it about 3 miles and parked it.
Has anyone ran across this before?
Tenet Nosce
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Nope, I never idle after start up for more than about two minutes.
I don't think you need to be overly concerned about it as long as it rides and runs normal. However, I would not idle the bike for more than a few minutes, unless you have to get out and get on it right away. Then I would probably just warm it up til the heads are at least warm to the touch, maybe 5 minutes max.
I thought you made a misprint when you posted this, but 40 minutes, what the hell were you thinking.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 14th December 2009
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is online now
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
Dont try to blame the Bike for your actions, All air cooled bikes need to have air circulation to cool. Check your Owners Manual, you will find it mentioned many times, do not let the bike idle for extended periods. Sounds like you got off easy this time. But you may have damaged some gaskets and or seals that will show up later.
scott1963 scott1963 is offline
scott1963 is on a distinguished roadscott1963 is on a distinguished roadscott1963 is on a distinguished roadscott1963 is on a distinguished roadscott1963 is on a distinguished road
I would change the oil and filter ASAP
ElectricCityIron's Avatar
ElectricCityIron ElectricCityIron is offline
Sportster/Buell Model: XL 883N
Other Motorcycle Model: Sportster
Other Motorcycle Year: 1991
ElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to all
Ya when i bought my 2010 iron the service manager made the point clear...DO NOT LET THIS BIKE IDLE FOR MORE THEN 10 MIN.....even that was pushing it. He did say to let it idle for a couple of min, or until rocker box was warm before riding though...but this is about a min min and a half at the most....
40 min...i let my bike idle once for like 5 min at 32 degrees outside and i got nervous, immediately taking it for an easy ride home from work...g luck
F.T.W Molon Labe
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You got lucky. These bikes need to move to keep cool. Never idle for more than five minutes.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Mbagger Mbagger is offline
Sportster/Buell Model: 883L
Other Motorcycle Model: Road King Custom
Mbagger will become famous soon enoughMbagger will become famous soon enoughMbagger will become famous soon enoughMbagger will become famous soon enoughMbagger will become famous soon enoughMbagger will become famous soon enough
Just because the knocking sound was gone for your 3 mile ride home does not mean it will not return.
Change the oil & filter right away.
If you are not under warranty, now might be the time to purchase an extended warranty.
colonelangus's Avatar
colonelangus colonelangus is offline
colonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nicecolonelangus is just really nice
x2
and dont mention this ever happened
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
The manual says not to let the bike sit and idle. On my 07 I never have.
shotgun46's Avatar
40 minutes oh my I am surprised it did not seize up on you
Sportsters Rule ! :banana
