0 Primary Oil INSANITY!
0 New member in MD
0 Decman's Birtday
Last Post: Outtakes
0 Oil??
0 Ei
Last Post: trappnman
0 What's your helmet?
Last Post: goblin_dust
Last Post: spacecoast
0 Rear tire
0 Salutations y'all
Last Post: cotton1
0 Show your tank decals
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: Heff
0 67 Sportster build
Last Post: ldurmon
Old 10th May 2005
HD1200R's Avatar
HD1200R HD1200R is offline
Sportster/Buell Model: XR1200x
Sportster/Buell Year #2: 1993
HD1200R is an unknown quantity at this point
Unhappy Broke Another Belt! Help w/ Belt to Chain Conversion
This makes broken belt number 3! Instead of spending the $150+ on another belt that i will break, I'm just going to convert to chain.
The parts that I figured that I need would be sprockets, chain, and chain guard. Should I also get a tensioner? What sprockets would you suggest going with for out of the hole performance and cruising?
1993 Harley Sportster 1200cc
2011 Harley Sportster XR1200x
Old 10th May 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
I guess that answers the question that was in my mind...
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 10th May 2005
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
3 Belts!!!? Do you have a lemon law in your state? 3 times same prob.= new bike!!!
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Old 10th May 2005
Mark_Bench Mark_Bench is offline
Sportster/Buell Model: Sportster Custom
Mark_Bench is on a distinguished roadMark_Bench is on a distinguished roadMark_Bench is on a distinguished road
I am betting you must have a bad sprocket, I am super hard on my bike and have never broken even one belt, and I weigh too much and launch hard and have been known to do the odd burnout and wheelie!
but as far as I know just get the sprockets, and a good quality chain...
Old 10th May 2005
HD1200R's Avatar
possible but the belt didn't show any abnormal wear. It just stretched and snapped. I'll take a pic of it when I get home.
I want to go with the DID 530ZVM chain but can only find sprockets made for the 520 chain. Would the bike be OK running a 520 chain?
The sprockets I'm looking at are made by Renthal.
Old 10th May 2005
tnichols's Avatar
tnichols tnichols is offline
Sportster/Buell Year: 1970
Sportster/Buell Model #2: Roadster
Sportster/Buell Year #2: 2016
Other Motorcycle Model: kAWASAKI
Other Motorcycle Year: 1979
tnichols is an unknown quantity at this point
Yes, I agree... You have some other problem to break 3 belts... Probably a bad sprocket or alignement problem.
I have a chain on my bike.. And I hate it... I wish I could swap with you...
Tom...
Old 26th May 2005
HD1200R's Avatar
I pulled the pulleys off and looked them over carefully. They look fine so I went on ahead and installed another belt for now. I'll do the chain conversion when it's freezing outside and just be a little more cautios with this belt. I think the belt might have been damaged while being stored for a couple years too. I didn't know that there was a max limit on how far you can bend the belt and so on so it might have been my stupidity on this one.
The first belt that broke was do to doing a burnout and switching from one pavement to another. It didn't snap but took out a foot long row of teeth instead.
The second belt was just too tight and snapped almost immediately. It was also a previous used belt that we had from another Sporty so age might have played a role on that one.
So far the failing belt issue has been my fault. I have the new one installed and measured how much movent the belt has so that looks good. One last thing I need to do is make sure the wheel is straight and I will be able to start riding again! Or at least after I am done with the project that I just started on the bike. I'll post that in a few but will be under custom finishing.
Old 26th May 2005
HD1200R's Avatar
Tom...
I thought they had belt conversions for iron heads? If not, I bet you could make some money creating a kit that is!
Old 26th May 2005
flskevin's Avatar
flskevin flskevin is offline
Be annoyed Now;Ask Me How
Sportster/Buell Model: 1200XL Custom
Other Motorcycle Model: FLSTC Heritage Softail
Other Motorcycle Year: 2008
flskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant futureflskevin has a brilliant future
Hey HD1200R, just dropping a line to a fellow Virginian. I'm not sure where Chesapeke is all I know is Ricky rudd is from there.
"... With Liberty & Justice for All." Must be 18, Void where prohibited, Some restrictions may apply, Not available in all 50 states.
Pastafarian Minister - Church of the Flying Spaghetti Monster
Dudeist Priest - Church of the Latter Day Dude
Old 26th May 2005
gwcrim's Avatar
gwcrim gwcrim is offline
Sportster/Buell Model: 1200 Sport
Sportster/Buell Model #2: Cafe el Roadkill
Sportster/Buell Year #2: 199?
Other Motorcycle Model: KX520
Other Motorcycle Year: 1989
gwcrim has disabled reputation
If you want a sprocket conversion, Zippers has all the parts you'll need.
~Crim~
My photo gallery: http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/184]
Similar Threads
Chain to belt??? LuxBlue Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 14 2nd August 2012 21:28
Belt to Chain Drive conversion AWOL Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 42 16th November 2009 21:03
Broken Belt kjbsporty Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 4 20th February 2005 15:03
2nd belt in 7 months, it was a gates as well Ekalb2000 Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive 6 13th December 2004 15:06
