Last Post: jordan1200
0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 900 heads contd..
Last Post: spacecoast
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 22nd December 2009
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
Default Don't Tell The Wife!!!!!! 88 Inch Kit ordered.
My Xmas present to myself! Just ordered:
Steel Engine Mount - adapts XB/'04XL heads to 86-03 XL
Item Number 55-16689-05
88 Cubic Inch Big-Bore Kit for 91-03 Sportster, use w/Thunderstorm heads, Axtell Nicom Plated Aluminum Cylinders, Iron Lined -
Item Number 004-NR3813CITSK-BH
Screaming Eagle .536 Lift Cams for 00-up Evolution XL/Buell
Item Number 11-2564901
Stage 2 LIGHT 04 1200R Heads
Item Number 003-NRHS-STG2XL12LGT-KP
Angle Cut Squish Band & Relieve Chamber for Thunderstorm Pistons
Item Number 118-005
Will use my 44mm CV and Supertrapp initially.
I went ahead as I found a local engineer to bore the cases!!!!!!
[SIGPIC][/SIGPIC] AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
VEEROD's Avatar
VEEROD VEEROD is offline
Sportster/Buell Model: 883 IRON/Now 1200 Iron
Sportster/Buell Year: 09
Other Motorcycle Model: 100th Anniversary V-Rod
Other Motorcycle Year: 03
VEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of lightVEEROD is a glorious beacon of light
Cool
Your wife should be happy look at all the money you saved by not going out and getting a new scoot
[B]If it look's good, you'll see it; If it sound's good, you'll hear it;
If it's marketed right, you'll buy it;
but....if it's real, you'll feel it.
Kid Rock!
[B]Good Day for a Bad Attitude[/B][/B]:smoke
shotgun46's Avatar
This is going to rock your world purchase several back tires and some wheelie bars and hang on tight oh and a video camera so we can see this bike run with you floppin off the back screaming Ha Ha Ha
Sportsters Rule ! :banana
I'll do a build thread and get some video when finished.
Just checked the registration rules and I will need to run std exhaust to get through rego every year. Thinking about some 2-2 headers with reducers for std mufflers when requred....Maybe dual supertrapps when not required (for rego).
Now looking for more parts. It never ends (thanks goodness).
Garry
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Congrats Garry! Hope your happy with it and keep us up to date on the work.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
Default bad boy
SHAME ON YOU!
Now enjoy your new 88 inch kit!
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Phillthy's Avatar
Phillthy Phillthy is offline
Sportster/Buell Model: 1200R+
Phillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura aboutPhillthy has a spectacular aura about
Good luck with it. Braver man than me!
Dead and soon to be burried.
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Congratulations!
How much you give me NOT to tell your wife!
Stuff: YES
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
So does that mean you were naughty or nice???
Any date that is not on your tombstone is considered a lucky day.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Congrats on your choice to go big bore. We'll need some photos and the cost sheet would be nice too. Please keep us updated.
