Tuning
Last Post: XLXR
New in NM
Last Post: spoon
30th December 2009
Posts: 298 Sportster/Buell Model: XLH1200 sport Sportster/Buell Year: 1999
1994 sportster 1200 owners, what is the STOCK part #?
The PO of my bike had the carb replaced supposedly with a
stock replacement. I have my doubts.
If any of you have a parts book or this bike in particular
could u please look up the part # for the factory carb for
me? I have the # from the one there now, but I want to
see first what the parts book says.
Thank you
30th December 2009
Posts: 722 Sportster/Buell Model: 883 XL converted to 1200 Sportster/Buell Year: 1994
My parts book has 27486-92A for a Calif 1200, 27487-92 for a 49 state 1200,
27503-92A for all models HDI & Swiss, 27488-92A for Calif 883, and 27489-92 for 49 state 883. These are the only ones listed in the book. Hope this helps, Roger
30th December 2009
Interesting, the carb on my bike is part # 27492-96. (no letter).
Now that I know what it should be, would u mind seeing where
my carb belongs?
Thank you for helping me unfold his mystery.
30th December 2009
Posts: 740 Sportster/Buell Model: XLH1200 Sportster/Buell Year: 1994
my carb belongs?
27492-96B Carburetor, 49 State, FXST/FLST/FLSTS
What I found on  .
The letters after the numbers are just revisions.
The higher the letter the newer, more improvements it's had.
30th December 2009
I don't have books for the later years but can tell you the carb is from a 1996 or later bike. In 96 the went to a 42 pilot jet in all the model carbs and that would be why the different part number. The last 2 numbers in the part number tell you what year it came out. If there is a letter, it tells you that it was revised that year, A would be the first revision, B is the second and so on. Just for info, I was running a carb from a 1999 Big Twin on mine. The only difference in the carbs is the bracket that the throttle cables sit in, the needle, main jet, and pilot jet. You can take any Harley CV carb and put those parts for your bike in and it should work just fine. Roger
30th December 2009
Thanks guys. The Jets on mine are a 145 main, and a 50 pilot. I have another thread
going about the bad mileage I am getting (24mpg/avg).
These jets were on the bike when I got it.
30th December 2009
So what's the difference between the sportster carburetor
and a carb from a FXST/FLST/FLSTS? Considering it's a carb
from a much larger bike engine, I would imagine that it us
designed to Feed the engine a larger amount of fuel right?
I might be in the market for a carb for my 94 xl 1200
from Any of you guys who have upgraded.
31st December 2009
You shouldn't need a whole new carb. I was running a 99 Big Twin carb on my 883 converted to 1200 and got better then 40 mpg even when I was tuned on the rich side. The carb bodies are the same as far as I can tell, just the jetting and needle is different. Also the bracket that holds the throttle cables but they probably switched that when they changed your carb. If it still had the 50 pilot then they probably didn't rejet it for your 1200. Get yourself a 42 or 44 pilot jet and a stock needle or even better a N65C needle at your dealer and stick them in. That should improve your gas mileage. Also check out he jetting 101 sticky for final tuning. Roger
31st December 2009
thanks Roger.. that was very helpful for me. I bought a few jets today, a 42 and a
45 pilot and the stock 170 main as prescribed by the factory manual for the 94 sportster
1200. I will get that N65C needle as you said and get all this together hopefully
tomorrow.
2 questions,
1. What advantage is it for getting that particular needle? Just curious.
2. the manual calls for a 45 jet as stock. Should I start there, or try the 42 first?
