Last Post: rickmodee
0 Leaks
Last Post: seanq2208
7 Long Road Trip advice
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
Old 30th December 2009
arkyboy's Avatar
arkyboy arkyboy is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Yamaha V Star 1100
arkyboy is an unknown quantity at this point
Default Cam Cover Question
I'm going to tear my 1970 XLH down this winter for paint and rechroming. My cam cover has had one of the distributor hold down bolt holes drilled out waaaaaay oversize by a PO. I have a spare cover in good shape, the cam bushings are used but look almost like new. My question is, could I use the spare cover without having to line ream the bushings or would it be better to have the oversize hole in my original cover welded up and redrilled to the correct size? Both covers are in about the same condition otherwise and will need to be rechromed, so the issue is only with the distributor hold down bolt hole. Thanks.
arkyboy
I'd rather dial 1911.
meanmechanic's Avatar
meanmechanic meanmechanic is offline
Sportster/Buell Model: sold XLH
Sportster/Buell Year: 1972
Other Motorcycle Model: VRSCR + BMW R1200C
meanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished roadmeanmechanic is on a distinguished road
As there are bushings in the spare and they aren't worn I'd use it. I would check it for clearances first though.
piniongear's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
arkyboy
If it were me my first choice would be to weld up and re-tap the hole.
A Tig weld will quickly fill it and drilling out and tapping is a simple matter.
Using another timing cover just because you have a 10-24 hole stripped does not make sense to me. You have 6 holes in that cover that need to line up with the crankcase holes and the chances that is going to happen is almost zero.
Just my 2¢ though.
pg
SCRACAR29 SCRACAR29 is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1969
SCRACAR29 has disabled reputation
Correct thread is 12-24. May think about Helicoil after weld-up.
Ivan RoachCoach's Avatar
Banned
Default You'll hear from both sides: It won't line up/It'll be fine. My...
...own experience, with friends who've bought spare cam covers to cut down instead of using their stockers, is that 9 times out of 10 the damm things won't fit right and will leak.
So, get that hole welded up and re-tapped or heli-coil it.
Life's too short to overcomplicate it.
Rogerwilko Rogerwilko is offline
Rogerwilko is an unknown quantity at this point
If helicoilng wont work you could have a steel threaded insert made.
Jafa39's Avatar
Jafa39 Jafa39 is offline
Sportster/Buell Model: XLH1100
Sportster/Buell Year: 1986
Jafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enough
+1 on that
Shake, rattle and roll...is there any other way to travel??
arkyboy's Avatar
I don't think I can use a helicoil, the hole has been enlarged to about 3/8" and it opened up into the hole for the distributor. Don't know what the OP's reasoning for enlargening the hole that much was, but it looks like a weld up & redrill is in order before I send it out to the plater. Thanks guys.
arkyboy
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
Default polish
dont plate
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
I looked through the thread again and if you're going to chrome-plate the cover, you'll have to rebush the cover anyway. take the spare, get it replated, rebushed, and save the money on welding, drilling and retapping.
