0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Old 12th January 2010
elviswongg's Avatar
elviswongg elviswongg is offline
elviswongg is an unknown quantity at this point
Default Here is a wide tire kit question
Hello everyone
Here is a simple wide tire kit question
I'm planing on adding the wide kit on my 05 sportster
Can we mount a 180 tire on the the stock rim ?? Or i have to buy an expensive larger rim $$$
Thank you
Charles: Charles: is offline
Sportster/Buell Model: 1200R Hardtail
Charles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to beholdCharles: is a splendid one to behold
180 is only 30mm wider than stock. Your issue would be hitting the belt/chain. Go out and measure between your stock tire and the belt then see what you have...if you've got more than 15mm, you should be good...20mm to play it safe.
Also, if you can fit a 180 on there, why would you need a kit?
jesse85's Avatar
jesse85 jesse85 is offline
Sportster/Buell Model: 883L
jesse85 is on a distinguished roadjesse85 is on a distinguished road
No the 180 tire is too wide for the stock wheel, but you can do a 180 swap much cheaper than a kit.... I did the 180 swap on my 08 883L. All you need is the wheel of your choice, i went with a 18" x 5.5" spoked wheel, a 20mm belt and a 20mm rear pulley. The belt i used is from an 06 softail and the pulley i'm running is from a 07 fatboy.... Anyways i have attached my various threads, if you have any questions just pm me. All the part #'s are in the first thread...
http://xlforum.net/forums/s...d.php?t=168208
http://xlforum.net/forums/s...d.php?t=192070
elviswongg's Avatar
Ok Thank you i read it
i realy like this look wow and seem to be a moderate budget modification
do you remember what are the widest of your rim ?
Old 13th January 2010
jesse85's Avatar
The rim is an excel 18 x 5.5 rim, if you want to know the actual width i can measure it for you....... It's much cheaper if you piece a kit together instead of purchasing one.
elviswongg's Avatar
No Thank you, i just got it on the net i appreciate your help
