Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 19th January 2010
nightsterfreak's Avatar
nightsterfreak nightsterfreak is offline
Sportster/Buell Model: Nightster 1200N
nightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished roadnightsterfreak is on a distinguished road
Default How do you replace 09 Nightster Rear shock?
I am thinking about getting progressive 412's for my 09 Nightster, but I have no clue how to replace them. Is there a special tool I need? Do I need to take the rear tire off? Is there a trick? Any input anyone?....thanks
Vassago's Avatar
Vassago Vassago is offline
Sportster/Buell Model: 1200N
Vassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to allVassago is a name known to all
One side at a time you will need a T50 torx bit. if yu have a bike jack it would be easier.
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
No you don't need to take the tire off. You will need a lift or something to hold the rear of the bike up, though. Then you just need a 50T torx bit and a box wrench to hold the bolt on the inside of the bottom mount. Get the weight off the rear end and unbolt your shocks. Make sure you keep up with where the washers/spacers go. If you go with shorter or longer shocks, you'll need to make some adjustments in the height of your bike or rear tire, so a lift is VERY useful when doing this. Another person there to help with the lifting/lowering is very useful, too.
And if you haven't heard this before, a factory service manual is the best investment you'll make in the bike.
________________________________________
PROUD MEMBER OF THE 'IGNORED BY '79' CLUB :banana __________________________________
[SIZE="1"][B]RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.[/B]
[B]"Dream as if you'll live forever. Live as if you'll die today."[/B] --James Dean
[B]"A narcissist is someone better looking than you are."[/B] --Gore Vidal
[B]"I just love the 'mechanicalness' of it"[/B]
--Indian Larry Desmedt[/SIZE]
I know this might sound cheap or ghetto....lol, but can i jack my bike up with a car jack if i stabilize it or should i quit being cheap?
Kirk the Jerk Kirk the Jerk is offline
Senior Bike Builder
Sportster/Buell Model: None
Sportster/Buell Year: None
Kirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to all
The only thing I'd add is, I'm told it's a good idea to replace those lower lock nuts with new ones when doing this. They aren't expensive, and then, of course, use blue threadlocker on both upper and lower mounts.
Thanks Kirk...I have been doing tons to my baby...speedo relocation, coil relocate, painting engine, headlight move, 2" tank lift...my next thing is move ECM and fuel pak, and replace shocks and seat...when I get done pics will be posted, hopefully next week!
Tyberius's Avatar
Tyberius Tyberius is offline
Sportster/Buell Model: 883C
Tyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really nice
If you want to be cheap, you can build a wooden lever bike jack using a 4x8 (or two 2x8s sandwiched together) and a length of iron pipe attached to a flange with the pipe passing through a drilled hole in the wood.
Search the internet or here for wooden motorcycle jack. I still use mine and I also have a lift.
08 883c commuter bike, mid-controls (including [URL="http://xlforum.net/forums/showthread.php?p=4205408#post4205408"]shift peg[/URL]), superbrace, rifle roadster fairing w/ tall shield, national cycle hand deflectors, h-d front signal relocators, mustang wide touring w/driver's backrest, passenger pillion and passenger backrest, h-d throw-overs w/drag specialties supports, sissy bar, NRHS Hurricane Oil Filter, oil temp gauge, deltran battery tender plus, otc lift, [URL="http://xlforum.net/forums/showthread.php?p=2172920#post2172920"]HD Handlebar clip :laugh[/URL], HD garage door opener, [URL="http://xlforum.net/forums/showthread.php?t=1442705"]WB hybrids[/URL]
thanks tyberius...i will give it a shot, i hate being cheap, but the army doesnt pay me enough to have to get finer things
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
IF you are replacing with shocks of the same size or slightly smaller you probably don't need to jack it up at all. One trick is to change ONE side at a time and crank up the preload on the shock that is still attached to firmly hold the bike up (and crank down the preload on the shock you are installing).
IF you are replacing with shocks that are longer it will be easier if you can jack up the bike - YES, you should be able to use a floor jack, but only if you're REAL careful (an extra set of hands helps).
All in all it shouldn't take you more than 15-30 minutes.
bone, when u say preload, you mean the knob that turns to tighten or loose shocks? they should be fully extended right to take the load off? or am i backwards?
