Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 18th May 2005
studebakerman2001 studebakerman2001 is offline
studebakerman2001 has disabled reputation
Default Oiling question?
On my 70' XLCH is the oil shared between the motor and transmission? or is there seperate weight oils I should be using for each? And if they are shared do both run through the oil tank?
Thanks guys
Old 18th May 2005
tnichols's Avatar
tnichols tnichols is offline
Sportster/Buell Year: 1970
Sportster/Buell Model #2: Roadster
Sportster/Buell Year #2: 2016
Other Motorcycle Model: kAWASAKI
Other Motorcycle Year: 1979
tnichols is an unknown quantity at this point
Your 1970 XLCH has basicly two places to put oil... The engine (in the oil tank) and the primary/transmission. The primary and transmission share the same oil. When you put oil in the primary, you are also putting oil in the transmission.
You normally want to put the same oil (20w50) in both the engine and the prim/trans. This is because there is a oil transfer valve that will allow some oil from the prim/trans to go into the engine. This happens if you put too much oil in the prim/trans. Its a safety, so you can't overflow the prim/trans... The excess will just go in the engine and end up in your oil tank. Harley did not want too much oil in the prim/trans because of the dry clutch used in there untill 1971. Harley removed the oil transfer valve in 1977.
Some people remove and plug the oil transfer valve so they can run different oil in the prim/trans. And I guess it works for them. But I don't recommend it. I still have mine. I find it is very handy. I never have to check my oil in the prim/trans. Every now and then I just dump some in there... I know I can't overflow it.
Good Luck,
Similar Threads
General Xl883 question MNewYork Rubber Mount Sportster Motorcycle Talk (2004-2006) 8 26th April 2005 11:50
Ignition Module Question 0ut1aw Sportster Motorcycle Motor - Top End 13 12th April 2005 01:10
Round AC Part Numbers Question Shamdog Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 5 22nd March 2005 23:35
Cam choice question shooter Sportster Motorcycle Motor - Top End 3 31st January 2005 20:36
Stupid question about controls Mechano Sportster Motorcycle Motor - Top End 22 28th January 2005 00:37
