Last Post: Diogenes415
Last Post: 883openpipes
Last Post: Blowupster
0 Stock vs. Modified
Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
0 first harley- help!!
Old 29th January 2010
dr.feltersnatch's Avatar
dr.feltersnatch dr.feltersnatch is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 08
Sportster/Buell Model #2: Xlh
Sportster/Buell Year #2: 77
dr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud of
Default best way to remove bondo
So the po of my ironhead did a bolt on hard tail and welded it then filled it with bondo. So what's the best way to remove the bondo? I was thinking a wire wheel in a drill maybe.
"A man dies when he does not stand up for what he knows is right"
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Bondo is quite brittle and I've used a pick-like hammer to knock it loose in the past. A chisel will also work.
Eric
Bic's Avatar
Bic Bic is offline
Bic is an unknown quantity at this point
I read in hot rod mag that aircraft paint stripper works well, may require several applications if the bondo is thick.
Bondo will also soften with heat. If you're planning on repainting your frame you could use a propane torch to heat the Bondo and it should crumble pretty easily.
Eric
BillieB BillieB is offline
BillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enoughBillieB will become famous soon enough
a small HAMMER and a chisel.
Old 30th January 2010
Coasty's Avatar
Coasty Coasty is offline
Sportster/Buell Model: 1200 XLC 100th
Sportster/Buell Year: 03
Sportster/Buell Model #2: 1200 50 XL 762/2000
Sportster/Buell Year #2: 07
Coasty is on a distinguished roadCoasty is on a distinguished road
I ose a small sand blaster with corn cob or wallnut shells, in a pinch a good quality paint stripper works well.
Coasty
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
All great suggestions..How about 100-80 grit sandpaper..works very well specially with an orbital sander or a little elbow grease
Bondo is a funny thing..it's strength depends on how hot it was mixed, (catalyst used) or how much moisture it's absorbed..Still a pain in the arse to remove.
Old 31st October 2011
ChooChoo's Avatar
ChooChoo ChooChoo is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Honda Goldwing
Other Motorcycle Year: 1990
ChooChoo is an unknown quantity at this point
Any shop that does powder coating will strip ity for about $50. They bake the frame in 600 degree oven which turns the bondo into ash and then they media blast it.
I guess I should update this thread huh? I ended up using a sawzall and basically rebuilt a bunch of my hardtail section. After I saw the very sketchy welds under the bondo I just cut it out and welder in some new tube.
