0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 19th May 2005
1974MONEYPIT 1974MONEYPIT is offline
1974MONEYPIT has disabled reputation
Default Jockey Shift Kits
Anybody know who sells or makes these kits for a 1974 Ironhead??
Thanks in advance
Old 19th May 2005
NXC1978's Avatar
NXC1978 NXC1978 is offline
NXC1978 is an unknown quantity at this point
If you can't find a kit, I am happy to give you advise about making your own. Also, you might try to contact Pilot. I think he was in the works for creating a kit, but not 100% sure.
Nick
Old 21st May 2005
frank's Avatar
frank frank is offline
frank is an unknown quantity at this point
i'm gonna build one for my '68 rigid. i have an idea that i think will work & let me shift with my left hand. nick, yours looks good but ours has a right side shifter--makes it a little more difficult. how did you hook up your foot clutch??
Old 21st May 2005
I wouldn't even need the foot clutch.....My bike has the shifter on the right hand side....any ideas for the linkage??
Old 23rd May 2005
NXC1978's Avatar
Frank- I cut down the stock cable and attached it to the stock foot shifter pedal.
1974moneypit- do you have any pictures to post??? I don't know what it looks like.
Old 23rd May 2005
frank's Avatar
that's what i planned to do---cut the stock cable & make a bracket to run it to my left forward control pedal, which is currently the rear brake. i will then rig the right pedal, which is now the shifter, to control the rear brake. the hardest part is to build a jockey set-up that will transfer from the right side to the left . i'm gonna first try bending a rod to come across the cases behind the rear jug---on my paughco set-up i've got plenty of room there. i'm hoping that i can just bend it in a "s" shape & make it work instead of having to use linkage of some sort.
frank
Old 23rd May 2005
NXC1978's Avatar
Frank- Sounds cool, you should post pictures when you make some progress. If you need any pictures of my shifter you can PM your email and I will send you some. Good luck with your project!!!!
Old 23rd May 2005
I'll snap some pictures the next time it's out of the garage
Old 23rd May 2005
NXC1978's Avatar
Cool! I am intrested to see them!
Old 24th May 2005
Here's a couple..they're old but you get the idea. I've changed some things on it since these were taken
