0 New in NM
Last Post: Vohnsen
0 C.O.B.B run west
Last Post: Zoharo
0 Kickstand identification?
Last Post: cotton1
Last Post: Vohnsen
Last Post: sltm1
0 What's your helmet?
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
  #81
Old 26th June 2012
gungatim's Avatar
gungatim gungatim is offline
Sportster/Buell Year: 79
Other Motorcycle Model: Yamaha TX500
Other Motorcycle Year: 74
gungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura about
the parts manual has the exploded view, from inside the case, on the kicker shaft the order is: Nut, Lockwasher, Gear, Engine case, Seal (square O-ring), washer, Thrust plate, then the sprlcket cover, spring, arm, etc.
PN for seal is 11101 for my '79 I can only assume they are same for most years but not sure. You can usually re-use the seal on the plug you removed from the kicker hole if it is not damaged.
Nolite Te Bastardes Carborundorum!
Old 26th June 2012
ppetersan ppetersan is offline
Sportster/Buell Model: XL
ppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the roughppetersan is a jewel in the rough
What a great turorial. I am one of the people who have been if there is any information on this exact procedure. I have the same bike as well. I may be pm'ing you to ask questions when I get this going - but probably a winter project for me.
Old 29th June 2012
74_XLH_WINCHESTER_VA's Avatar
74_XLH_WINCHESTER_VA 74_XLH_WINCHESTER_VA is offline
Other Motorcycle Model: Sears/Gilera 106SS
Other Motorcycle Year: 196?
74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold74_XLH_WINCHESTER_VA is a splendid one to behold
Originally Posted by ironman74 View Post
12. Install the new Oil Seal on the back side of the case. This is a little tricky to get in, but I managed to get it installed using two long straight screw drivers and a little bit of patients. Just get one side in and work your way around.
Do you know the part number of this oil seal? When you say "back side of the case" do you mean that ths
seal is installed from the inside of the case? In picture 12 it is hard to see a seal
in picture 13 you show the shaft, the shim and another seal. Are there two seals? One at the inside of
the case and the one from picture 13 which is on the outside of the case.
Is there a source here on xlforum that shows the assembly and part numbers?
Thank you very much,
Mark
"Do you know the part number of this oil seal?"
- I don't have my parts book in front of me at this time, so I am not sure of the part number for that oil seal.
"When you say "back side of the case" do you mean that this seal is installed from the inside of the case? In picture 12 it is hard to see a seal."
- No, the seal is installed into the outside of the case through the pass through hole in the motor mount. The top picture in step 12 is the inside of the case looking through to the outside, you can see the lip of the seal just beyond the bronze bushing. The bottom picture in step 12 is the outside of the case looking through the pass through hole in the motor mount the black inside of the silver-looking ring is the oil seal.
"In picture 13 you show the shaft, the shim and another seal. Are there two seals? One at the inside of the case and the one from picture 13 which is on the outside of the case."
- No, the photo in step 13 is to show order of installation. The oil seal is the same seal as installed in step 12 into the outside of the case, then comes the .007 shim, then the thrust plate, then the kicker shaft.
"Is there a source here on xlforum that shows the assembly and part numbers?"
- I am not sure. This thread is my source for the assembly, and as for part numbers I can see if I can get that info for you or you can pick up a parts book online or at your local shop. The kit that I installed was a complete kit from J&P Cycles as said at the top of the very first post.
K.C.
Old 6th April 2013
shooterj2003 shooterj2003 is offline
shooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to allshooterj2003 is a name known to all
I guess you feel secure with threaded fasteners over rivets? We're they screws of special type,eg,stainless,grade 8 etc. and I would guess locktite is used.I've alway's heard rivets were called for-I would not want even one screw backing out!
Old 6th April 2013
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Red lock tite and grade eight, I believe. I plan to do mine the same way. Gets rid of out of center slipping kicker for good. Well until everything else around it wears out.
Old 9th March 2014
kelticdodge kelticdodge is offline
Sportster/Buell Year: 1976
kelticdodge is an unknown quantity at this point
Default Rachet plate to clutch shell
I read your post ,outstanding pictures,How much would you charge to replace a riveted rachet plate with screws ? I am new to this site and my computor skills suck like a vacum cleaner . You can email me at kelticdodge@aol.com Thanks,Tom.
Old 17th March 2014
Twisted Nightster's Avatar
Twisted Nightster Twisted Nightster is offline
Sportster/Buell Model: IRONHEAD
Other Motorcycle Model: ROAD GLIDE
Twisted Nightster is an unknown quantity at this point
would welding up the kicker gear (rivet holes) to the back of the clutch plate work? Any thoughts on welding this then grinding if necessary to smooth flat instead of drilling holes? i just got a complete kit to install on my 74 xlch
...........Don't take LIFE to Seriously, YOU will NEVER make it out ALIVE...........
Old 17th March 2014
Your masterlink clip is pointed the wrong direction....
Old 17th March 2014
dondoucette's Avatar
dondoucette dondoucette is offline
Other Motorcycle Model: Fatboy Lo
Other Motorcycle Year: 2011
dondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the roughdondoucette is a jewel in the rough
I had mine drilled and tapped.
Old 17th March 2014
ok so i drilled the holes for the gear and taped for bolts. Got the primary back together minus the cover and i attempted to turn the kicker on the pedal side and there is no give on the kicker arm with a wrench. I am just trying to get it to turn just a little so that i can feel more comfortable before putting covers on. The Trans was in Neutral when i tried. Does this sound normal just after a new equipment installed kicker? they where new parts never installed on 74 xlch. thanks
