0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 Curious as to what I actually have
Last Post: JakRabbit
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 THE Trainspotting Thread
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 24th July 2007
maddhatter777 maddhatter777 is offline
Sportster/Buell Model: 1200XLC
maddhatter777 is an unknown quantity at this point
Default $250 for Dyno Custom Tune Worth It?
The closest dyno is about an hour away. Is it worth the $250 get it tuned? I know it is the going rate but it just seems a bit much. All they are doing is properly jetting the carb right?
Old 24th July 2007
blakjak's Avatar
blakjak blakjak is offline
Sportster/Buell Model: Honda CBR 929RR
blakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura about
That and timing so that the bike runs properly throughout the whole RPM range.
IMO - if you've got a built engine/conversion, it's worth the money. If you're running all stock or a stage 1, save your money and do it yourself. You can get it really close with a little time and tuning on your part.
Old 24th July 2007
All I have is a set of troublemakers and a SE air cleaner. Nothing special. So I'll do it myself..... Thanks for saving me some money!!!
Old 24th July 2007
CT1200's Avatar
CT1200 CT1200 is offline
Sportster/Buell Model #2: Buell xb12r
Sportster/Buell Year #2: '09
CT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the roughCT1200 is a jewel in the rough
Well step one is to do a few pulls to get a base line.
Then adjust the carb as needed.
Do a few more pulls to see results.
Then readjust. Repeat as needed.
It could take them a good 2hrs to do, it could take 4hrs...
Plus parts, and what not. There not just jetting the carb.
If they are then your getting screwed. I'd stick around and watch if you could, its fun to watch your bike on the dyno. Depending on how you ride it though you might think they are trying to blow it up.
Undeniably Nerdy...
Exceedingly Cool...
Keep an eye on the road... Theres always something to see.
[SIGPIC][/SIGPIC]
Old 26th July 2007
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
Default let's put it this way
As noted in a post in the NRHS section, at the NRHS 4th party, Aaron tuned Phelan's bike for 7 more HP (phelans bike is a stock 1200S with stage 1 mods) and tuned another guys 98HP 88 inch bike for another 18HP! NRHS charges about 250 bucks +/- for a dyno tune. The tunes were on the house by the way, but even if they paid for them, the results were more than worth it.
A good quality dyno tune is going to cost you about 200-300 bucks but, if they are good tuners, they can extract a lot of hidden HP as shown in the examples above. Money well spent in my opinion no matter how stock or modifed your bike is.
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Old 27th July 2007
flibuoy's Avatar
flibuoy flibuoy is offline
Other Motorcycle Model: Softail Deuce
Other Motorcycle Year: 05
flibuoy has disabled reputation
Best $ spent...horsepower gain, rideability and insuring engine is not harming itself. My FI Deuce Stage I gained 11 HP and 16# torque....AND ....it was running great going into dyno. The tuner is way important to be satisfied with results...the dyno doesn't tweak it...the tuner does with help of OBJECTIVE dyno. The gains shown above are about twice what the parts alone added with a decent running tune...for about 20% of total cost. Throttle respose, mileage etc are ALL improved. And no I don't sell dynos...oh the 1200C is Stage I carbed and dynoed and runs right with the Deuce. John
Pray for rescue but row for shore
Old 27th July 2007
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
If you don't plan to do anymore engine work, then $250 might be worth it if the tuner is really good. Otherwise you end up paying a lot of money for nothing. It's all about the tuner and his skill. If you plan to do more engine work, then I would get it done and have it tuned. That way it will be $250 worth of tuning instead of $500. It's only a waste of money if the tuner sucks.
2005 XL1200C
Those who trade liberty for security have neither.
Old 27th July 2007
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
I saw Dr. Dyno tune a bike for $300.00, and he added lollipop tuners to the shotgun pipes + rejetted the S&S carb. It started too rich with a torque dip 2500-4000 RPM, but left spot on AFR-wise with better low end torque.
Old 29th July 2007
Well I found out today my local dealer has a dyno. Good chance I'll be scheduling an appointment with them. $60/hr average 2-4hrs. Guys are "schooled" (dyno college) so it should be worth the cash. The only issue now is to think about adding any parts so I don't have to do it more than once!!! haha.
Old 29th July 2007
ReddTigger's Avatar
Another thing to do is ask questions. BEFORe they tune, Find out exactly what you're going to be getting. Find out what they plan on doing, ie how many warm up pulls? where do they start the baseline for the chart? how many pulls after changes?
Have some idea as to whats going to be happening to your bike...
Otherwise you can just look at em and say. "uhokay!" when they tell you your bike needs this that and the other thing. (ie dynojet, yost, new carb, ecu, etc.)
States I've Ridden in
71.3 hp 70.8 tq
