0 Winter Storm Warning
0 Is this 1200R worth $4500?
4 The no-debate OIL POLL
Last Post: bplinson
0 Celebrating Sportsterpedia's Third Anniversary
0 68 xlch wiring
Last Post: Zach68
0 joyride memories xlx ironhead
0 Does Synthetic Engine Oil cause Higher or Lower temps at the oil tank?
Last Post: Sportycus
0 Mustang's new seat? Anyone tried it?
0 timing troubles!
Last Post: The Doctor71
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Calcustom
0 XL883L 2006 coughing and backfiring
Last Post: Bama Lee XLC
0 How many helmets?
0 Clutch Spring plate poll
Last Post: bimbo
0 What oil temp do you run
Last Post: JKKO
Last Post: 1977iron
0 Who's still riding???
Last Post: 1977iron
0 Bushing alignment
0 Helmet poll
0 Pull cam cover for powder coating
Last Post: spoon
5 Jiffy Standing
Last Post: rurlndum
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
Old 2nd March 2010
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Default How Sweet It Is!! (All Andrews Tranny)
Finally got my '78 back together after rebuilding the tranny with all Andrews gears and shafts, new shift forks, bearings, etc. Needed the rebuild to eliminate a slipping 2nd gear problem due to worn fork and shifter cam. Also replaced the swingarm bearings while things were torn apart.
Oh my, how nice she shifts now! Exceptionally smooth shifting, no banging and clanging and no more popping out of 2nd. Each shift is butter-smooth with none of the lever kickback I used to get, especially going into 4th when really cranking on the throttle.
Definitely worth the $920 I paid for all the gears and shafts, plus another couple hundred for the bearings, forks and various shims I needed. Money well spent as I can now hit the highway knowing the tranny is in tip top shape. If you have a tranny problem, don't hesitate to tear it apart: this was my first and it was pretty easy with the factory manual and the Haynes for additional info.
Eric
Old 2nd March 2010
SilverShark96's Avatar
SilverShark96 SilverShark96 is offline
SilverShark96 is on a distinguished roadSilverShark96 is on a distinguished roadSilverShark96 is on a distinguished road
Wow, that is a steep price. But hey, if you needed it, then you needed it. Sounds like quite an advancement for your Ironhead. Definitely some to keep in mind when needing something similar.
Transmissions, over anything else, scare me. The complication factor is definitely there.
1978 Harley Ironhead - the Italian Rat
Old 2nd March 2010
Yeah, I know what you mean about the $. I probably could have reused the OEM gears and shafts since they weren't in bad shape, just some slight chipping on the gear dogs. But, I figured that while I was in there I'd go ahead and make things as perfect as possible. With the engine mods I'm running, the motor pulls exceptionally strong and I wanted to ensure there wouldn't be any problems down the line.
It was actually quite fun to have the assembled tranny on the bench and see how everything fitted together. Also nice to find the problem areas that were causing my 2nd gear troubles. It's not rocket science by any means but does require some patience and a good manual to see how things fit together.
Eric
Old 2nd March 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I agree. Worth every penny. Stock gears are trash in comparison.
Old 2nd March 2010
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
Did you keep the same ratios?
Old 2nd March 2010
scottericsonon scottericsonon is offline
Sportster/Buell Year: 1965
scottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enough
Eric
i had thought that was pretty cool myself when i had mine here on my desk.....
mine was the same way........if you remember correctly i fell into that all andrews trans on ebay but otherwise i would have done the same thing....as long as its apart you might as well do it RIGHT
anybody know anything about 727 automatics??
i picked up a 440 powered 1976 club cab W200 4X4 with no reverse recently.....
i can part it out for like 4 times what i have in it (at least) but its a pretty solid truck and VERY saveable.......
Always remember to pillage before you burn
Old 2nd March 2010
Yes, I kept the stock ratios. I'm quite happy with the 22/51 sprocket combo I now run and since I've never ridden a Sportster with different ratios I didn't want to experiment with my hard-earned $. Bike pulls like a mother for a non-stroker.
Eric
Old 2nd March 2010
Gone Gone is offline
KEEP that truck, they are awesome. 727's will lose reverse if you beat the shit out of them, ask me how i know. lucky for you, its an easy fix, find a hotrod shop that specializes in Mopars, the 727 was a very popular trans. if your in the Detroit area, PM me. i know right where to take it.
Old 2nd March 2010
Ivan RoachCoach's Avatar
Banned
Default Any tranny upgrade is a good thing, stuffing it with Andrews...
...components is a solid investment in peace-of-mind.
You can tear that four-speed to hell and back (burn-outs, hole-shots, etc.) with COMPLETE confidence when you've got it rebuilt with the best parts in the business.
Good choice!
Old 2nd March 2010
Good choice!
Ah, burn-outs are unnecessary punishment to the bike. But hey, that's another topic.
