Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
883, faster, performance, sportster, upgrade
Old 2nd March 2010
CNord09's Avatar
CNord09 CNord09 is offline
CNord09 is an unknown quantity at this point
Default 883 performance mods
hey guys. i have a 883 sportster with se plugs and wires. looking for performance upgrades and users who swear by them. i have drilled holes in my stock baffles for sound but have come accross a few extra dollars for slipon exhaust and a/c and "power comander" (what im going to call it.. efi upgrade thingamajig) whats some easy/moderate performance upgrades i can do to get more performance i know my way around a wrench and understad a motor.
Slip on names and people who have had them and like them..
a/c names (**arleness stage two?? seen it and like it? maybe? ideas?)
efi thingamajig
ideas........
i just want more power with it. i ride with bigtwins so i need to beable to rep for us.
when i hear music like this it makes me wanna peel out!!
black '07 883, mini apes, red grips, vance and hines shortshots, speedo relocation, wire tuck, coil relocation.
Old 2nd March 2010
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of light
I have an 883 and simply changing to a good air cleaner and slip on mufflers along with a retune is your best bang for the buck.
You don't have to go high dollar in that area unless you want to, the SE offerings in the AC and muffler department do a good job, especially on an otherwise stock motor.
Do you ride 2 up?...if not you can go reduce weight by ripping off things you don't need.
*Taking off back seat (if you have one) and rear passenger pegs/mounts
*Sissy bar (if you have one)
*Anything else you can think of
Reduced weight can have the same effect as added power.
After this stage the real money starts.
Old 2nd March 2010
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
there's no replacement for displacement.......
for about $700 you can get a completely bolt on in 1 day NRHS 1250 kit......that will out power just about anything you can do to an 883......
Ww
master wizard
RIP Mr Jimi
"All The Way"
Old 2nd March 2010
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
I second what racerwill said...displacement is the cheapest upgrade for the power at this point for you.
I do or have used the SE Stage 1 A/C, the NRHS Hurricane A/C, stock with a K&N A/C, and a Big Bore Intake (cheap version of the Heavy Breather). From a performance perspective I suspect they are all very close, with probably a slight edge to the Hurricane.
I do or have used Cycle Shack Slipons, SE 50 State legal slipons, and D&D Fat Cat 2-1 exhaust. The SE's sound plenty loud to me, but aren't loud in comparison to most other bike exhausts. The Cycle Shacks were noisy, but not obnoxious. The D&D's have a cool 2-1 sound and are very loud depending on the RPM, but also have the best performance out of the bunch (I don't have any dyno sheets to prove that tho).
The fuel management, you have quite a few choices and decisions to make. Decide if you want to do your own tuning and decide how picky you are. If you aren't going to fiddle with it yourself, talk to the local shop to see what they recommend. If you are comfortable with computers and want to do it yourself I highly recommend the TTS Mastertune. If you want to do it yourself, but it just needs to be close enough then use the Power Commander as there are plenty of maps out there for most configurations. (For what it's worth, I've used the SE Race Fueler, the SE Race Tuner, Daytona TCFI, and TTS Mastertune for tuning at various times. I've also helped a buddy with his Power Commander...now both my bikes use the TTS).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 2nd March 2010
Gone Gone is offline
I gotta go with the others on this. Well mostly I guess. I have rode beside a few EFI 883 powered sportys with similar modifications to what you and the guys are kickin' around and I got to say they are plenty quick. Sure, given enough time a 1200 will win out, but for around town and hitting the twistys there isn't much difference.
Most of the upgrades you can do on a 883 will carry over to a 1200 when and if the time for conversion comes.
Now keep in mind that this is my personal observation and others may agree/disagree in part or all. That's whats great about this forum, you can take what you read here and balance it with what you see/feel and end up with one badass ride.
Enjoy the ride,
Bud (Halcyon1)
Old 2nd March 2010
ReddTigger's Avatar
Since you have a 2007, The TTS Mastertune would be a good choice if you want to do it yourself.. (If you're able/capable) if not, I recommend going with the Screamin Eagle Super Tuner at your local dealer (or buy one online and get your INdy to install it) P/N 32109-08A
Much improved responses over the Power Commander/Fuel Pak.. Haven't had a chance to test the TTS Mastertune, (But they did build the Race tuner for HD)
States I've Ridden in
71.3 hp 70.8 tq
Old 2nd March 2010
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
I use a power commander and have no complaints.
Old 2nd March 2010
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The air cleaner comes with this kit along with everything else you need. Can be bought at 20% off from several online Harley dealers. I wouldn't do the ECM flash but I'd go with a PC-V. This is the most power for your money.
Screamin' Eagle® Sportster® 883cc to 1200cc Stage I Conversion Kit
Make your Iron 883™ roar. This complete conversion kit will alter the personality of your 883-equipped Sportster® model. Designed to bring your XL883 model up to XL1200 specifications, this kit includes Sportster® Stage I Air Cleaner Kit, XL1200 Cylinder Heads, and XL1200 Cylinders and Pistons. Kit includes black highlighted cylinders and cylinder heads. No case machining is required for installation. Street legal when used with stock mufflers. All models require ECM calibration (priced separately).
29784-07
Fits '07-later XL883 models.
MSRP US $1,199.95
Old 2nd March 2010
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
First off, often the main reason people are left behind on Sportsters is because they try riding them at too low RPM. If that's not you, here's some things to think about. If you get the best, most expensive exhaust and aircleaner, you'll only be getting a horsepower or two over most other performance exhausts and aircleaners. Unfortunately that's the nature of the 883. IMO, check ebay for CS slipons or SE slipons as well as any aftermarket AC that are compatible with your year. Just about any decent muffler, AC, and related download should be good for a 10HP boost up top, but you might loose some HP under 3k RPM.
Back in the day, the stock 1200's only put out about 10HP more than the stock 883's, but now-a-days the 1200's have considerably better flowing heads, which gives them a 15+HP difference in stock form. Because of the better stock HD 1200 heads, the 1200 will benefit more with HP mods... again usually talking above 3k RPM. BTW, NRHS has mentioned that the SE 1200 heads are less than desirable.
Check out some of NRHS's kits on their website too.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
Old 2nd March 2010
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
I know I have a carbed bike, but my 1200 conversion only came to a little over $500 including the cams and newer style heads. If you're patient and watch Ebay and similar sites, you can come away a winner.
The screamin eagle conversion kit is a great deal if you have the money.
If money is an issue, just do the 1200 flash after your conversion until you can save enough money to buy one of the other FI controllers.
Your limits are self-imposed by what you let your mind believe
