Last Post: mor
Last Post: BILLETPROOF
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 2nd August 2007
Rob Henderson's Avatar
Rob Henderson Rob Henderson is offline
Sportster/Buell Model: XL883/1200C
Sportster/Buell Year: 03
Sportster/Buell Model #2: FLSTF FATBOY
Sportster/Buell Year #2: 07
Rob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura about
Default Quick Question - Kickstart
Just a quick question. I have searched but have not found...
What was the last year for a kick-start on Harleys. Was it the same for all years or was each model different?
Thanks
2003 XL883/1200C
Ceramic Bassani Sweepers, Forcewinder A/C, SE IGN, Wiseco 9.5.1, S&S Super E, Progressive 412's etc. etc, etc.
No More sporty......2007 FLSTF - FATBOY - I am a traitor!
Old 2nd August 2007
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
I believe 1979 was the last year a kickstart was possible. From '80 on the primary case was not drilled out for the kicker shaft and they relocated the rear master cylinder down where the shaft would normally exit the sprocket cover. I have a kit for my '78 to add a kickstart that I'll be installing this winter.
Eric
Old 2nd August 2007
roadster roadster is offline
Sportster/Buell Model: SEVERAL
roadster has disabled reputation
'79 for the XL's and '85 for 4 speed big twins.
Old 3rd August 2007
Thank you very much gentlemen.......
