0 TC88A maps for 1250 Sporty
Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Old 12th August 2007
Guz's Avatar
Guz Guz is offline
Sportster/Buell Model: Sportster 883cc Anniv
Sportster/Buell Year: `03
Other Motorcycle Model: Honda Vtx 1800cc F1
Guz is an unknown quantity at this point
Default Help, Help
Guys,
I bought the other day the Nostalgic grip for my Nightster, but waoo what pain in the neck..I need some help, especially with the right hand..I`m Lost big time..
Guz
h2ocreeker h2ocreeker is offline
h2ocreeker has disabled reputation
What's the problem? If you want to loosen old grips or put new ones on, rubbing alcohol works great.
Guz's Avatar
Guz Guz is offline
That I should do,How I put the rubbing alcohol...Yes I `m tryng the get rid of the old and put the new ones..
KC_Sporty_Gal's Avatar
KC_Sporty_Gal KC_Sporty_Gal is offline
Sportster/Buell Model: XL883C (1235 Conv)
Sportster/Buell Model #2: XL883R
KC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to all
A factory service manual is a wonderful thing... on the right hand make sure you wedge a small piece of cardboard in the brake lever. There is a small switch in there that controls the rear brake light... it is fragile and many a person have broken it.
You need to adjust the throttle and idle cable to give enough slack to release the barrel ends from the old grip. Roll back the protective rubber cover to get to the nut. Be careful as those barrels on the end of the wire have a tendency to go flying or fall on the floor never to be seen again.
To remove the left grip you might have to cut it off. I did when I did mine.
Erica in KC (Red)
"Ruth" '05 XL883C -> 1212 -> 1235 (don't ask) - Pearl Yellow
Progressive Fork Springs, Progressive 412s w/ heavy duty springs, 883 -> 1200 NRHS conversion (at 1235 Now), Daytona Twin Tec Ignition, Hurricane AC
Guz's Avatar
Guz Guz is offline
Ok, I`ll got try all this input...Keep U guys post in a while...Hey thanks to all of you for the tips.
Guz
Guz's Avatar
Guz Guz is offline
Talking
Left side done...
Guz's Avatar
Guz Guz is offline
Hey hey
Success, Grips are on, and look FREAKING awesome..Thanks to all of you..Now let hit the road..is a Beautiful day here in WPB, FL..
Guz, ,
