0 Removing oil key from shaft
0 What's your helmet?
Last Post: Hellbent_4
Last Post: 308bever
0 New England 2018
0 Folkie's Rural Rambles
0 How many have repainted?
0 Help with my clutch please
Last Post: DirtyHarry68
0 Primary Oil INSANITY!
Last Post: Will1250
5 Didn't winterize my bike... am i screwed???
Last Post: hscic
Old 28th March 2010
rifrafracing's Avatar
rifrafracing rifrafracing is offline
Sportster/Buell Model: xl 883
Sportster/Buell Year: 88
rifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the roughrifrafracing is a jewel in the rough
Default 03 XB9R Firebolt Engine In Sportster
I have an 88 sportster
looking at putting an 03 xb9r engine in it
will it bolt up?
will the sportster intake manifold fit?
what ignition could I use-stock sportster?
Old 28th March 2010
rottenralph's Avatar
Nice bike. I don't believe bolting right up is going to happen. I would look at some of the frame suppliers for sporties to see where the mounts are located when using an XB motor. Who makes the swingarm you are using?
Old 28th March 2010
what does bolt into the 88 frame?
I was told the early(up to 03) 1200 lightning engine
cyclone engine?
swingarm is actually an 06 honda cbr 1000,upsidedown
Old 28th March 2010
My message was a little disjointed. I meant frame suppliers because I know some of the buell frames take XB engines. I would use a five speed lower end and mate a 1250 to it with XB style heads(1200 after 04). Nrhs Performance sells the 1250 kit and they have a dyno room that will make it evident that a 100+ engine is possible to put in your frame. I am not sure if a rubber mount engine will go right in.
Where is the rear shock hiding?
Old 29th March 2010
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
The 2002 and earlier engines will fit with no major issue. The XB engines have totally different mounting points. It can be done with severely modifying the frame, but the 2002 and earlier engines have 4 bolt holes in the rear where it mounts to the frame. The XB engines do not have this, as they have a swingarm pivot mount in place of the holes.
The Sportster intake manifold will fit.
Your limits are self-imposed by what you let your mind believe
Old 13th July 2014
xlron's Avatar
xlron xlron is offline
Sportster/Buell Model: 1100
Sportster/Buell Year: 1987
Sportster/Buell Model #2: 1000 xlh
Sportster/Buell Year #2: 1980
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
Hey Buellster's , I need a 1/2 inch off set front pulley. Will a big twin 1 & 1/2 pulley fit my buell cyclone splines? And all I can find in 29 tooth is 3/4" and wider offsets. Call Baker? Vulcan? Kicking myself in the butt for not using a chain. Simple, like me.
