0 XL Bomber - Portuguese project
Last Post: d10221
0 Dellorto PHM38 Parts Sources - Intake Rubber, Throttle Cable
Last Post: nakina
0 Setting Timing, 1964 & Earlier Mag
0 Ironhead engine problem?
0 900 clutch in a 1000 engine Strociek
0 72 ih stroker advise needed
Last Post: toe
Last Post: toe
0 NOS cases
Last Post: DR DICK
0 Strociek Project Help Needed
0 WTB S&S super B parts
Last Post: bretton
0 Another question re: Microsquirt
Last Post: gl90hog
0 North central Mass
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
3 Wtb, Wts, Wtt, Wtg (Evos)
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
0 1100 bathtub heads on a 883?
Last Post: JimVonBaden
Old 7th May 2010
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Do those Side Shots have a crossover?
Old 7th May 2010
LuxBlue's Avatar
I checked the website and answered my own question.....yes, they have a crossover "power chamber", something my Short Shots don't! On my bike I replaced SE II mufflers that used the OEM crossover tube with the Short Shots and didn't notice any extreme change in power. I often wonder though what I'm missing without a crossover?
Old 7th May 2010
rokdoctor's Avatar
rokdoctor rokdoctor is offline
Sportster/Buell Model: Hardtail
Sportster/Buell Year: 1970
rokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the rough
They have a good rumble but arent too loud in my opinion. I keep the stock baffles in. It has a decent bark at full throttle but otherwise is a very mellow rumble.
RokDoctor
http://xlforum.net/photopost/watermark.php?file=50526
Old 14th June 2010
shotgun46's Avatar
Dang thing looks good
Old 14th June 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I'm a big fan of 2:2 pipes and have been doing extensive tuning of 3 different sets in the last year on my bike. Although all of them are a little different, some characteristics are always common.
If you have a decent baffle in them you always loose top end, but most of the time you improve the mid range.
The main benefit of a balance tube is you can have a little more baffle to improve the mid range without hurting the top end as much, so you end up with a little more average hp. Not necessarily more peak power though, because if you run a good open baffle like a Thunder Monster you'll already have pretty good peak power.
Old 14th June 2010
Kirk the Jerk Kirk the Jerk is offline
Senior Bike Builder
Sportster/Buell Model: None
Sportster/Buell Year: None
Kirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to all
Glad I read this, I'm looking to do the opposite, solid mount pipe on a rubber...
Old 14th June 2010
TonyC's Avatar
TonyC TonyC is offline
Other Motorcycle Model: FLHRSI
TonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of lightTonyC is a glorious beacon of light
Excellent job and they look great!
Both bikes deserve a bump!
Tony C.
I'm a relatively respectable citizen. Multiple felon perhaps, but certainly not dangerous.
