0 Reasons
Last Post: jordan1200
Last Post: Roosterman
Last Post: Jowniofownio
0 Feeling in trouble.
0 Engine dies when choke off
0 project 74 sporty
0 Parrothead's 2018 Spring Maintenance on old Sporty
0 ParrotHead's Mods For My "New" Sporty
0 first harley- help!!
0 Please help! Oil flow problem after rebuild
Last Post: kaveebee
Last Post: cotton1
0 99 1200s clutch drag
Last Post: Ranchero50
Last Post: r4fthrs
0 Head gaskets.
0 2002 Sportster turns over but doesn't fire.
Last Post: Ben221
Old 4th April 2010
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of light
Default connecting rod length
Well, I listened to a friend and assumed all lower end parts in an ironhead are pretty much interchangeable, but I guess I was wrong. I get a good deal on a set of rods at a swap meet. They were listed as for 1981-85 sportster. Well, my indy told me they won't work in my 64, that they are slightly longer than my older rods. Does anyone have the specs on these rods and the older rods? How much longer are these rods? Also, does a two hole pin or a three hole pin matter?
Old 4th April 2010
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Rods are the same part number from 57 to 78 but I dunno about 81.
Hard to imagine a change of rod length from 78 to 81 when there was no other changes to the engine that would require it.
But you never know.
Maybe someone with a later parts book can check it out.
Old 4th April 2010
billy bob's Avatar
billy bob billy bob is offline
Other Motorcycle Model: Custom Rigid XL
Other Motorcycle Year: 2007
billy bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nicebilly bob is just really nice
Info I found : 57-early 81, oem#24275-57 --- late 81-85, oem#24275-80A
*Rod length is the same= 7.440"
** The only mention of rod length difference, was when the EVO XL was introduced.
Rod length was reduced by 1/2"
Crankpin is shown as oem #23960-54, 3-hole, Sportsters and K models, 54-early 81
Old 4th April 2010
The newer parts book uses the term "commonized taper" with the -80A. I do not know what this is, but i recall a discussion from some years ago where this is a technical improvement? The part number is otherwise the same so i think more info is needed to make a decision.
Old 4th April 2010
tracbike's Avatar
tracbike tracbike is offline
Sportster/Buell Model #2: Sportster XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Trac Dynamics / Razor,
tracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the rough
It is not rod "lenth"but the crank pin....as of 81, flywheel tapers were commonized.
after 3/81 flywheels, crank pin, pinion,and motor sprocket shafts will not fit interchange, except as a complete set
newer crank ppin has a smaller keyway, and only one oil hole instead of three.
there are differences in pinion and motor sprocket also.
Old 4th April 2010
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
The commonized taper is in reference to the tapers on the crankpin, sprocket shaft, and pinion shaft. It doesn't have anything to do with the rods themselves. My parts book shows P/N 24290-57 (connecting rod, rear) and 24294-52 (connecting rod, front, as fitting all the way to 1985. The P/N only changes to a -80 number for a set of rods, since a set includes the crankpin.
As far as a 2 hole vs. a 3 hole crankpin, I've never seen a 2 hole crankpin for Sportsters, anywhere, and I looked for one just recently. Where can I get one?
Old 4th April 2010
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to all
yup, later ironhead rods are still 7.440. I measured mine while it was out. I don't know what the different part number is for.
the 2 hole crankpin I haven't seen but someone just got one and wondered about why it only had 2 oil holes. Now I vaguely remember hearing something that might explain it. I don't remember the source, but it went something like this:
"the three hole crankpins proved to flow too much oil and the rollers would skate on the oil film rather than rolling and would develop flat spots. So they started making them with fewer holes to allow just the right amount of oil"
Old 4th April 2010
Ok, so the taper on the crank pin is different. Are the rollers and retainers different? Can I just get a new crank pin that"s the same diameter as the one in my rod set that fits my engine and use the rods and rollers I have now or do I need to change the pin, rollers, and retainer?
Old 4th April 2010
78ironhed 78ironhed is offline
Sportster/Buell Model: ironhead sportster
Sportster/Buell Year: 1979
78ironhed is an unknown quantity at this point
Heres some info that might help.
how do you calculate the bearing size. Well it ain't rocket science, but like so many other things mechanical it does take at least a half a brain and decent tools. First off, measure the crank pin diameter. In my case the crank pin mics out to 1.2480”. Then measure the inside diameter of the rod races. Use a telescope gage and then measure the length of the telescope gage. In my case the rod races mic out to 1.6265”. Then subtract the pin diameter from the race diameter and you end up with .3785. Now you need to factor in the desired running clearance that is about .001”. So subtract .001” from .3785 and that will leave you with .3775”. Now divide that number by 2 and you will end up with the desired diameter of the rollers. So the desired roller diameter in this case is .1887. A standard roller is .1875” so I need a roller that is .0012” oversize. Got all that?
Connecting rod big end inside diameter 1.6265”
From which subtract the crankpin diameter - 1.2480”
The result = .3785”
Now subtract the desired running clearance -.0010”
The result = .3775”
Divide that by 2 to get desired roller size = .1887”
Subtract standard roller diameter to get oversize -.1875”
Desired oversize = .0012”
Closest available oversize = .0010”
As it happens I have a set of standard size rollers, at least the digital readout vernier caliper would have me believe they are standard size, and they felt a little loose when I test fit them so a .001” oversize should be just about right. So that is what I will order and hopefully they will fit just right. Actually I decided to hedge my bet a little. I also decided to order a set of .0008” oversize rollers, just in case I was off a little.
Finally, these are the rods I've decided to use. I found this set in my dumpster diving a couple of months ago. No nicks or scratches on the bearing surfaces, out of round by less than .001, I think they will be just fine. I had contmplated buying a set of new S&S rods, but $300.00 plus gets to be a chunk of change and this set looks damn good. A word to the wise, there are other " stock" rod sets sold in the various catalogs. Those rods sell for about $100.00 less tha the S&S rods and I think they are made in China. I bought a set once and tried to use them. I could not true the fylywheels with those rods installed, the best I could get them down to was about .006" out of round, that is way to much for a crank assembly. I think the tapers were cut wrong. In fairness, I may have just had a bad set, anyway, I sent them back and will never buy a set of rods that are not genuine HD or S&S.
