0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
0 More of a reintroduction
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
Last Post: Slidesquad24
0 oil cooler or not?
Last Post: Tucsonmax1
oil pump fitment
Old 11th April 2010
alaska62sporty alaska62sporty is offline
Sportster/Buell Model: '74 XLCH engine
Sportster/Buell Year: 62
alaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura about
Question What year oil pumps work for a 1974 engine?
Anybody know what years I need to be looking for on ebay? Engine is a 74. I know they made some changes, just not sure when. Thanks guys.
Tag-less
Old 11th April 2010
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 2008
Other Motorcycle Model: XLRTT
72 till 76 are fitted with the same oil pump...
BUT from the outside, it looks exactly the same as the older ones (several variations on these as well...), you'll need to look inside to see the diffs...
As a quick check, if it's got the wide slots breather tower, .512 wide from memory, it's a post 72... But you can only measure it proper when its apart...
Patrick
Flat Head Forever
Old 11th April 2010
Thanks for the help.
