Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
0 Value of a Boattail?
Last Post: Monte03
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Old 16th April 2010
treerat's Avatar
treerat treerat is offline
treerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura abouttreerat has a spectacular aura about
Angry ATTN. wix 51348 oil filter
about 1,100 miles ago I put amsoil 20/50 and a wix 51348 oil filter on my bike.
i was always a little paranoid about not using a hd filter because I could never see the oil moving well in the oil bag. well for the last 300 or so miles of testing trying to get jetting set up and exhaust and baffles sorted out, I have developed a rattle in the lower end that I at first thought was a primary chain, and ajusted several times over the last 3 days and couldnt get the sound to go away. well the filter was always in the back of my mind, so I got in the car and made a 120 mile trip just to get a dam filter. swaped filters out and started bike up and can NOW see good movement of the oil, started raining so I wont be test rideing to day to see if my noise is still there, but if it was the filter not flowing well enough I would assume the noise is still there because the crank bearings and or rod bearing is proabaly toast!
BE VERY CAUTIOUS IF YOU CHOOSE TO USE THE WIX FILTER!
Old 16th April 2010
I have never understood folks using car filters on their bikes just to save a few bucks.
Old 16th April 2010
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is online now
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
Was the Wix filter sold to fit your bike, Or did it just fit so you screwed it on? If it was sold for your bike you may have legal recourse, If it was sold for a cars high pressure system then its your Bad.
Old 16th April 2010
rocketmangb's Avatar
the 51348 is speced for some Harleys
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 16th April 2010
FoxsterUK's Avatar
Me neither. Why do people think that some random filter will be better or more economical in the long term than a HD filter? I mean, its not a complicated or expensive item, why risk screwing your engine?
Same with oil really. I see people sticking all kinds of weird grades of oil in, like single grade in both holes. Why? What do they imagine they know that HD doesn't?
Fox
I had an '05 1200R.
Old 16th April 2010
I never see oil flow in the tank
About a year ago i put a Caterpillar filter on my bike and developed a rattle shortly after.
changed filters and the rattle was still there.
started thumping the pipes and found a loose baffle in the front pipe causing the rattle.
Also think about this for a second
The bypass in the filter operates at about 8 psi differential pressure.
As soon as the pressure exceeds 8 psi more on the outside of the media than inside it opens and the filter bypasses allowing all of the oil up the center without filtration and almost zero restriction.
I doubt the filter caused a problem.
Old 17th April 2010
treerat's Avatar
I have done a bunch of reading on here since I posted this and I might have another possibile answer:
could it be a front primary sprocket (compensator nut) backing off causeing the noise?
also I had to be getting some flow with the wix because it would raise the oil temp in the tank to 150 to 175 depending on how I drove it, in about 30 to 40 miles.
but it defenatly has better flow in the tank with the hd filter.
I noted when I switched them that the wix has a blue flat rubber, I assume anti flow back valve under the outside inlet holes in the filter and the hd filter does not have this flat rubber piece.
Old 17th April 2010
melcheld's Avatar
melcheld melcheld is offline
melcheld has disabled reputation
51215 is the correct p/n for Wix's filter for Sportsters. It is a motorcycle specific filter.
51225 if you want it in chrome.
Now if I have suspicion a felony's been committed, I can just walk right in here anytime I feel like it because I've got this badge, I got this gun, and I got the love of Jesus right here in my pretty, green eyes.
Old 17th April 2010
melcheld's Avatar
I just saw that Wix does also spec the 51348 for all sportsters.
Sure its the filter and not a coincidence? If it really was the filter, Wix should owe you a new motor as all their literature specifies that filter for use on XL's.
Old 17th April 2010
treerat's Avatar
just thought of something, went fishing in the oil tank with a strong magnet, stirred all through the oil and drug it all over the bottom of the tank and did not get even one speck of metal, so that has to be a good sign right? iI would think if it were something as catastropic as a rod or crank bearing that there would be at least some small amount of metal carried to the tank by the oil?
