Last Post: seanq2208
7 Long Road Trip advice
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
Old 5th June 2005
Danny3nose's Avatar
Danny3nose Danny3nose is offline
Sportster/Buell Model: XL 1200 Roadster
Danny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really niceDanny3nose is just really nice
Default Do I Need an Oil Cooler?
Wondering if I should put an oil cooler on. Do alot of 2up riding in the city, as well as take alot of trips. (passenger and cargo) Also do alot of solo riding as well.
In Memory of Mr. Jimi...
Old 5th June 2005
82ndJumper's Avatar
82ndJumper 82ndJumper is offline
Other Motorcycle Model: FLHRI Cobalt Blue
82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice82ndJumper is just really nice
it depends on how hot it gets. If you live in the desert, Vegas, Death Valley or where its hot then yes. Since you live in Cleveland then probably not. Get a oil dip stick with a Thermo on it.
RIP JohnnyG, you are missed.
Old 5th June 2005
dwardy dwardy is offline
Sportster/Buell Model: '92 883/1200
dwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished road
Danny, invest in one of those oil temp dip sticks. They're reasonably cheap and will tell the tale. Chances are, you won't need an oil cooler.
Old 5th June 2005
Hi..Geese 82nd, I guess you never ben to Cleveland in the summer, it get hot.
Ok, since you are doing alot of heave load riding, A oil cooler sure would not hurt, unless you forget to use a oil thermostat.
It goes between the cooler and the engine and keeps the oil at temp, if it's too cooled, it by-passes the cooler. Oil needs to be at temp to work right, if you don't use the termostat, you will keep the oil too cooled, and it can do m ore harm then good.
Old 5th June 2005
Danny3nose's Avatar
Do they make an oil temp dip stick for 04's and up? Didn't see one in the HD catalog.
Old 5th June 2005
Moved On Moved On is offline
Clicky Here
Gazza
Old 5th June 2005
Danny3nose's Avatar
Thanks Gary!
Old 6th June 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Where we live? I should think not.
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 31st January 2006
fealingood's Avatar
fealingood fealingood is offline
fealingood is an unknown quantity at this point
At what oil temperature should a person be thinking about getting an oil cooler?
Shark Doctor's Avatar
Shark Doctor Shark Doctor is offline
Shark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the rough
Danny-
If you decide to go with one, they are relatively easy to install. Just helped install one of my riding buddy's 2003 Dyna, and it was a breeze.
It DOES attach to a front motor mount and requires the use of a lift under the motor to realign the motor in order to put the bolt back in, but that was minor.
Only problem we encountered was that the mounting hex head screws were huge (11mm) and we could NOT find an Allen wrench that large. SO.... we found a cold chisel at Sears that was hex-shaped and - yup - 11mm in diameter. Cut the chisel end off, inserted it into an 11mm socket and made our own "hex."
God. The things we do for the love of our bikes!
-J
