0 Sportster or Street Bob
Last Post: Bone
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 no rear brake light
0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: 60weight
0 New member in MD
Last Post: xraytoken
0 Help me with gas cap...
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 1968 XLCH Oil Leak
Last Post: 72 Ironhead XLH
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
Old 22nd April 2010
JDRAKE4200's Avatar
JDRAKE4200 JDRAKE4200 is offline
Sportster/Buell Model: XL1200
JDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enoughJDRAKE4200 will become famous soon enough
Default Front cylinder running lean
All,
I am a little concerned. My front clinder is running lean. My front pipe started to turn blue, so I pulled both plugs to see how my jetting was. The rear is about perfect. The front however, is white with little black spots. I checked for a leak using propane as well as carb cleaner. No increase in RPM's. Is it normal for one cylinder to run leaner? Should I tune the carb so that the rear is rich and the front is perfect? should i close the gap a thousandth or 2 on the front plug? please help as I do not want to hurt my baby. Please help.
little background:
open pipes 1 3/4 stepped to 2 1/4
aftermarket air cleaner (k&N)
run 91 octane or above
45 pilot 170 main (jets)
Air fule mixture screw 3 turns out
Old 22nd April 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Yes, it's perfectly normal. The engine is air cooled and the front cylinder gets much more "air flow" than the rear cylinder. Therefore, the rear cylinder will run a little hotter than the front cylinder. I wouldn't get overly concerned about how your plugs look. To read them properly you should do a "plug chop" but, with all the ethanol fuel it's hard to read plugs anyways. If you start getting a lot of popping during deceleration (as long as you don't have open/straight pipes) your probably not running too lean. With your open pipes your going to get some popping on deceleration so I wouldn't get overly worried about it. If it starts to back fire or you get popping while your accelerating then your probably running lean or, more likely, have an exhaust leak. The only way to really check it accurately is to get an air/fuel ratio meter.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 22nd April 2010
jharback's Avatar
Your double posting. That's normally considered a no, no. See my answer to your other post.
Old 22nd April 2010
DIESEL's Avatar
DIESEL DIESEL is offline
I would invest in a dyno run to see if you are actually lean.
I have a similar set up on my 05. I simply replaced the 42 with a 45 slow jet. I haven't had any issues.
Old 22nd April 2010
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Or get a baseline pull on a Dyno for about $50.
Old 22nd April 2010
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
JDRAKE4200, please don't post identical duplicate threads in different sections. Decide what one section it should go in, and leave it at that.
If you're getting no responses, bump it up, or ask a mod to move it.
Thanks.
Folkie
South East England Riders
Old 22nd April 2010
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
This is the one part of your post which would concern me more than the rest. It appear it is detonating. Can you hear this under hard accleration? Maybe not with drag pipes. The front cylinder actually runs a little warmer than the rear. The pipes will change regardless so don't use that as a guide. I'd back your timing off a degree or two and see if that helps. Secondly I'd replace the intake seals if they are more than a couple of years old. I have had more than one set that passed the WD40/Propane tests but were leaking anyway. And put in a new set of plugs.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 23rd April 2010
cowboy770's Avatar
cowboy770 cowboy770 is offline
cowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of light
keep an eye on your oil usage. I had the same problem with my 04 1200 where the front cylinder was lean and was also getting a ping. The valve seal was leaking. You will know by the sparkplug will have a black coating baked on it. Just a thought
Old 23rd April 2010
JDRAKE4200's Avatar
Default Thank you
Thank youf or all of the responses. I appreciate all of your help. Sorry bout the double post, I will kepp thin in mind for the future. Thanks again everyone.
Old 5th July 2010
ashmead ashmead is offline
ashmead is an unknown quantity at this point
Ever figure out why the front was lean? I have the same issue with my EFI Roadster. Rear plug looks great, nice and tan. Front is too white for my taste. Front runs 30-40 degrees hotter than the rear, and it should be the other way round.
I'm going to check the connection of the pipe to the cylinder. could be a leak. I had to loosen the pipes to install SE slip-on mufflers. Maybe it worked loose.
