Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 Tap extention?
Last Post: T. Clark
0 Tank swap
Last Post: Grymy
0 How do you upshift?
0 Lowboy frame conversion
10 Anyone else noticed this? (Horn Closes Choke)
0 Oil Hose replacement help.
0 Spokes or Mags
0 New From CA
Last Post: jcro61
Last Post: MXHD55U
Last Post: Crosshairs
Old 1st September 2007
SportyJohn's Avatar
SportyJohn SportyJohn is offline
Sportster/Buell Model: XL883R/1212R - SOLD
Sportster/Buell Model #2: XB12Ss -Long
Sportster/Buell Year #2: 2008
SportyJohn is on a distinguished roadSportyJohn is on a distinguished road
Post 2008 XB12 Ss Long- TPS problem!!
Picked up my new 2008 XB12Ss on Thursday.first thing i noticed was a rough idle and poor throttle response.This only happened from idle to about 2000 rpm.Took it back to the stealer on Friday.It took the service dept. 3 hours just to look at the bike and another 3 1/2 hour to diagnose the problem.
They determined that the TPS needed resetting, but did not know what to reset the voltage at.(no Service Manuals for the 2008's yet!!?) Anyway,they shotgunned the problem and the bike does run good but could be better. Overall i'm very happy with my purchase. AWESOME bike.
I'll post pics tonight.
2008 Buell XB12Ss - Drummer Exhaust, K&N Filter, XOPTI Tuned
SportyJohn's Avatar
Default New Bike Pic
Here's the new bike!!!
Old 30th October 2007
speedybuell
Guest
Posts: n/a
Default ditto
I have the same bike, and I have had the same problem. My stealership told me that all buells do it and that the only thing that would fix it would be a race ecm... they dont even make those for the 2008! But from what I am reading the 2008 ecm is adaptive and shouldnt need tuneing, I am breaking mine in a little to see if it gets better.
whittlebeast's Avatar
Other Motorcycle Year: 2008
If thes bikes are "Brand New" then give it a few miles (like 300 miles) for the ECU to self learn. The Harley got lots better with time. I think the Buells use a MAP based EFI logic. If that is true then the TPS setting (assuming it is working) is not all that critical for the EFI maping. They are fairly easy to test if you have a good Multi Meter.
AW
Old 3rd December 2007
JADE1200S JADE1200S is offline
Sportster/Buell Model: XL1200s
Sportster/Buell Model #2: Buell XB12Ss
Other Motorcycle Model: Honda VFR800A
JADE1200S is an unknown quantity at this point
You got to give these things some time to break in!
My '08 XB12Ss was rough the first couple of days, but I notice that it is slowly getting better.
Break in is a 1,000 miles, and I figure that is what it is for, ... seat the rings, educate the ECU, etc.
First several hundred miles you will have some excess blowby and the ECU is going through it's learning curve.
You need to call Al at American Sport Bike and ask him about direct link software. what it does is actually resets your ECM to help with the EPA mandated lean condition your bike has to have stock.
His phone number is 1-760-727-2333
Just tell him Dan from NRHS sent you and he should be able to make your bike run great!
Old 4th December 2007
nallac's Avatar
nallac nallac is offline
Sportster/Buell Model: X1
Sportster/Buell Year: 00
nallac is on a distinguished roadnallac is on a distinguished road
I thought the 08's were going to have automatic TPS reset, everytime they started up??.
I remember reading about it somewhere,????.
92 883/1200/883/1200
8" TBars
FXR tank
S&S Super E
SE II's
SE Ign
Not enough power...
Old 20th December 2007
SportyJohn's Avatar
Default Resetting TPS on 2008 Buells
According to the Service Manual, with the '08 models the TPS resetting is accomplished without the need for a plug-in diagnostic tool:
Have the Run/Stop button set to Run.
Turn the ignition key to the On position but do not crank or start the engine.
Open the throttle fully to the stop and hold it there for one second.
Close the throttle fully to the stop and hold it there for one second.
Repeat the throttle open/close procedure a total of three times in succession.
Turn the ignition key to Off/On/Off/On/Off in succession to complete the procedure.
I have tried this & it works. - John
