Last Post: BluBeaSSt
Last Post: jcro61
0 90 in. Build
Last Post: mac93
Last Post: 883openpipes
0 New England 2018
0 Forty-Eight Special and Iron 1200 Sportsters announced today
0 Sportster or Street Bob
Last Post: seagullplayer
Last Post: conv90
Last Post: hscic
Old 23rd April 2010
XLFREAK XLFREAK is offline
Default Pushrod tubes and new cylinders
I just spent an hour trying to install the clips on my pushrod tubes. Two popped on rather quickly but the other two wouldn't go. I tried all different kinds of screwdrivers, spun the tubes to different positions, strained until one of my nads fell out and rolled under the cabinet (I'll get it later). Finally, I figured out that rough spots on the castings of my new cylinders were in just the right place to catch the sliding collars just before I got them low enough to put the clips on. I bent up a thin piece of sheet metal to slide behind the collars and the clips popped right in. Watch out with new cylinders. I've already had problems getting the base nuts on (see my other thread on these adventures).
Old 24th April 2010
Use the clips and the screwdriver to lever the collars down. Place the screwdriver blade on the collar, angled down slightly. Put the clip into the top of the PR cover where it seats into the rocker cover, with the screwdriver blade under the clip. Lever the clip into place.
Somebody posted great pictures of the process, but I can't find them.
Old 24th April 2010
Originally Posted by 85mm View Post
... I figured out that rough spots on the castings of my new cylinders were in just the right place to catch the sliding collars just before I got them low enough to put the clips on. I bent up a thin piece of sheet metal to slide behind the collars and the clips popped right in ...
I had this on the rear cylinder of my 1980, and have it now on the front cyl of my 1978; 1 tube on each. I use the lid from a plastic yogurt container having trimmed off the lip around the edge. It is good for a few uses then it is worn out. The tin would be better - if you have it. I have yogurt containers.
Old 24th April 2010
72Iron's Avatar
72Iron 72Iron is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Harley-Davidson
Other Motorcycle Model: FLHTCU (Geezer Glide)
72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice72Iron is just really nice
Let me guess, you're very cultured.....
I have yet to figure out the perfect way to make the task easier, but I'll keep practicing.
I gave up smoking, drinking and sex.
It was the worst fifteen minutes of my life.
RIP: Eli
Old 24th April 2010
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
I think there's a purpose built tool to help do this but I've been just using brute force for so long I can't be bothered buying them. As long as you have 3 hands it's not that hard.
(It's a shame all of mine are keft hands but there you go)
Old 25th April 2010
Mud's Avatar
Mud Mud is offline
Mud is an unknown quantity at this point
Through years of struggling with harley's stupid push rod tube set-up, I discovered a tool for installing clips. A simple paint can lid opener that i got from Lowe's when i got some paint. The flat hook fits great in the clip, and the "T" handle lets you grip and push. It makes this miserable process a little easier.
Mud E. Mudhole
Old 25th April 2010
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
I think what 85mm is saying is the cup was hanging up on a fin or rough nub of the cylinder castings. Are they Import cylinders? When the cups are loaded down from the outer area of the cups with a screwdriver I believe they angle inward which limits clearance even more.
Old 26th April 2010
... When the cups are loaded down from the outer area of the cups with a screwdriver I believe they angle inward which limits clearance even more.
This is exactly what happens with the spring retainers/cups. And they carch on a cylinder fin. Sliding a thin piece of tin or flexible plastic in behind the pushrod tube is the solution to this problem.
Old 26th April 2010
This is my first IH and it's got lot's of surprizes for the beginner. I'm sure the cylinders are asian made. I'm gratefull that I can still get the parts, but many of my new pieces don't fit exactly right. Oh they're close, but you know someones pumping these things out without feedback from the customers. So you've got to always watch out for the little aggravating things that constantly come up with new parts. Hope this thread saves others some frustration.
Old 26th April 2010
Jafa39's Avatar
Jafa39 Jafa39 is offline
Sportster/Buell Model: XLH1100
Sportster/Buell Year: 1986
Jafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enough
Don't assume that because the fit is a little off that they are Asian....some US-made IH parts are like that...
Shake, rattle and roll...is there any other way to travel??
