Last Post: 60weight
0 New From CA
Last Post: 60weight
0 FNG from OKC
Last Post: GeoK
0 Oil Hose replacement help.
Last Post: McQueen
0 Shotgun Porn
Last Post: GeoK
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 New in NM
Last Post: GeoK
Last Post: bfarrell
Last Post: felis
  #41
Old 4th March 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Schwede gave great advice. Don't bother doing much else until you *fully* charge the battery, clean all the battery connections, ensure when you retighten the connections they are "wrench tight", and I would also suggest pulling the system and starter relay (replace if they have any signs of corrosion).
Since you are clearly having battery issues, continually bump starting it won't help. The fuel pump and ECM require a bit of energy. So, if your battery isn't charging you are continuously draining it. These batteries will die a premature death if you take them to nothing. And the ECM won't even try if the volts get too low.
I suspect the issue is one of the following - battery connections, relays, or battery. Of course, it's entirely possible you do more damage by thrashing it.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 13th May 2012
powellsanmiguel's Avatar
powellsanmiguel powellsanmiguel is offline
Sportster/Buell Model: XL 833C
powellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enoughpowellsanmiguel will become famous soon enough
Thank you all again for today. Farley the Harley stopped in a gas station in RAISIN TX, and wouldn't start. I called Progressive, since they tow on my insurance and sat down.
About twenty minutes passed and a young couple came for gas, on a lovely bagger, and eventually asked why I was sitting rather than riding. And we began to trouble shoot; lights work, starter works, plenty gas, WTF? "It can't be too hard," although I was sure it could.
When we got to the fuses I saw those damn relays and a bulb shone on in my senile brain, "Those suckers fail, the result is just like this, and I bought a spare years ago when I read about the problem in the Xlforum!" Found relay, replaced it, its the lower one, and Farley started right up. Thanked the kid profusely, rode home.
And thank you again, one and all!
Your motorcycle is like your toothbrush, but it hurts a lot more if you drop it on your foot.
Old 14th May 2012
Glad Farley was able to go on without a tow. I think it might be a good idea to replace the relays as a maintenance item.
Old 14th May 2012
Quite so, and a spare or two on board.
Old 21st October 2012
Rocknvipe29's Avatar
Rocknvipe29 Rocknvipe29 is offline
Sportster/Buell Model: Iron
Sportster/Buell Year: 2012
Rocknvipe29 is an unknown quantity at this point
I got a 2012 Iron with 53001 miles won't start just backfires like its out of time.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
That would normally make me think about the crank position sensor, but the rest of the story from your thread has me scratching my head.
Old 11th May 2013
muddawg's Avatar
muddawg muddawg is offline
muddawg is an unknown quantity at this point
had the same relay problem a few months back and after pushing my bike 5 miles home and figuring out it was relay i now carry 2 spare relays with me at all time
Old 2nd October 2013
the1337aaron the1337aaron is offline
Sportster/Buell Year: 1973
the1337aaron is on a distinguished roadthe1337aaron is on a distinguished roadthe1337aaron is on a distinguished road
how the hell did you put 53k miles on in one year?
Old 4th November 2015
Sportster/Buell Model: XLH883
Other Motorcycle Model: 2012 XL 1200 custom
hammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the roughhammer6315 is a jewel in the rough
SPST single pole single throw
