0 Engine dies when choke off
Last Post: 60weight
0 Help please...77 xlch oil line routing diagram image?
Last Post: 69sscamaro
0 Won't rev past 1200
Last Post: Aocasio
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
Last Post: halfmt1
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 newby from Australia
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 too bad
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
Old 6th May 2010
BIKER BIKER is offline
Sportster/Buell Year: 1981
Sportster/Buell Model #2: XL1200 Custom
Sportster/Buell Year #2: 2013
BIKER is an unknown quantity at this point
Default Idle Setting When Adjusting Throttle Cables
My question is this: I can never find anything on the internet I really need/want to know, and this is an example. When installing new throttle/idle cables, or adjusting the ones that are already on there, do you set the idle screw at the point where it just begins to engage or 1/2 turn (or some other distance) beyond the engagement point, (s&s super e). In other words, at what setting should the idle speed screw be at before you begin to install or adjust your throttle cables, or does it even matter?
Old 6th May 2010
Mike83XLX Mike83XLX is offline
Sportster/Buell Model: XLX1000
Other Motorcycle Model: Honda V30 Magna
Other Motorcycle Year: 1984
Mike83XLX is an unknown quantity at this point
I've found this link extremely helpfull for info on the S&S Super E...
http://www.sscycle.com/admin/uploads...ns/51-1012.pdf
Old 6th May 2010
SilverShark96's Avatar
SilverShark96 SilverShark96 is offline
SilverShark96 is on a distinguished roadSilverShark96 is on a distinguished roadSilverShark96 is on a distinguished road
Install your throttle cable so that there is no tension on the throttle pivot at the carb. Slack enough for no tension, but not too slack where you need to turn a bunch of degrees on the handle bar to get the tension.
As far as the idle screw, it's a 1/2 turn when the screw makes contact. You just want to open up the throttle a crack, and that'll give you a good idle, or at least a good starting point to tune that idle.
1978 Harley Ironhead - the Italian Rat
