0 Sportster or Street Bob
Last Post: RKN
0 Drive Chain Adjustment
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
  #1081
Old 21st July 2011
godcity108 godcity108 is offline
godcity108 is an unknown quantity at this point
Originally Posted by Zoidberg View Post
looks nice!
any front pics? I'd like to see how you mounted the headlight.
is that A/C good enough (for performance) ?
Here's the new headlight mount set up.
and here's the way i had it before with the custom bracket thingee:
Old 21st July 2011
Originally Posted by YOURADHERE View Post
Diggin what you did with the switches/controls. Any pics of the switches you mentioned?
here are some pics of the early stage of getting the switches installed into the side cover. let me tell you drilling out those 1/4" holes with one hand on the drill and the other trying hold down the cover was a pain in the arse. keeping it from sliding all around was a bitch.
Old 21st July 2011
by the way, in the great state o' texass you only need a hi/lo beam switch and a horn to pass inspection, or so it goes. so for this switch relocation i just added an On/Off toggle for the fuel pump, and two momentary push switches for the horn and starter, and then i had to track down an On/ON toggle switch for the hi/lo beam. ended up finding one at fry's around here, but it has to have the three prongs on the business end. but honestly if i were to do it all over again, i'd solder the fuel pump wires together, and just leaving it on, since i kill the bike by turning the key to Off.
Old 21st July 2011
Gone Gone is offline
I just used a vertical licence plate mount on mine and took off the flip out plate and all that junk.
unfortunately in Italy you can't mount the licence plate on the side, only centrally.
Old 21st July 2011
rmaytee's Avatar
rmaytee rmaytee is offline
Sportster/Buell Model: Forty Eight
rmaytee is an unknown quantity at this point
I'm loving your bike godcity! Well thought out mods.
Old 21st July 2011
Looks great!
What did you use for tachometer relocation ?
Old 21st July 2011
thanks dude! but a lot of these ideas came from these forums or youtube vids of guys chopping their shit, trying to get it right. so i really appreciate that!
Old 21st July 2011
Looks great!
i think you mean the speedo mount on the side. i just used this piece from these guys:
http://www.summitracing.com/parts/ATM-3209/?rtype=10
BUT if you're gonna do this to a 48, you're gonna need to get longer bolts and some extra washers, because when other people did it with their Nightsters or whatever, harley made the speedo cover a bit different. on the 48, it's literally a plastic cup like thing. on the older sportys it's more of a plate. so getting the rubber mount and metal ring to fit around the 48 speedo you gotta pull it apart at the clamp/mount part. and that's where the extra washers and longer bolts come in. just an FYI.
Old 22nd July 2011
WildThang's Avatar
WildThang WildThang is offline
Sportster/Buell Model: 48
Other Motorcycle Model: FLHTC
Other Motorcycle Year: 2009
WildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of lightWildThang is a glorious beacon of light
modified the badlander seat...
2009 FLHTC
2005 FLSTI w/Ranger Sidecar
2010 XL1200X
Old 22nd July 2011
drd1135's Avatar
drd1135 drd1135 is offline
Senior Bike Builder
drd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud ofdrd1135 has much to be proud of
That's the look.
