0 Value of a Boattail?
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
  #2121
Old 12th June 2012
cpracing519's Avatar
cpracing519 cpracing519 is offline
Sportster/Buell Model: XL1200X Forty Eight
cpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud ofcpracing519 has much to be proud of
If your talking about the center Sparto taillight on the fender, its just a red taillight only. It's from Licks Cycles. I use it as a running light only.My side license plate holder is stock off the 48 and it has a white light that lights up the plate. I have Alloy Art fender strut LED's mounted on the end of the strut frames that are my brake lights and blinkers.
Old 12th June 2012
darkdesign's Avatar
darkdesign darkdesign is offline
Sportster/Buell Model: xl883c
darkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to behold
thanks heaps for the info, i was hoping to run as a brake light, and mount the lic. plate under it where you've got 'sucker punched' but i need to have a white light illum. the plate to keep 50 off me. The search continues.....
Old 12th June 2012
Not sure if any Sparto lights have a white light/lens included. I know my Sparto light sheds enough light though to light up the plate if you had a plate mounted to it, it would be red though. I had the Sparto light as brake/running light last year when i had my stock taillights/blinkers on but then went to the LED's and decided to make them the blinkers and brake lights. I didn't want the LED's on all the time as running lights.
Old 12th June 2012
darkdesign's Avatar
i'd prefer to do it the way you have, but want to keep the bike road legal, less headaches.
Old 12th June 2012
misternikko misternikko is offline
Sportster/Buell Model: Buell XB12Scg
misternikko is an unknown quantity at this point
Those strut LEDs are awesome!! Do they fit the strut without cutting it like you did? Are they easy to wire up?
Old 12th June 2012
Sportster Spence's Avatar
Sportster Spence Sportster Spence is offline
Sportster/Buell Model: 48 (XL1200X)
Sportster/Buell Model #2: Sportster Hardtail
Sportster/Buell Year #2: 1994
Sportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to beholdSportster Spence is a splendid one to behold
I've got a Sparto light on my 48 with the plate mounted to it, I used litz n bolts to mount the plate thus solving the problem!
Old 12th June 2012
YOURADHERE's Avatar
YOURADHERE YOURADHERE is offline
Sportster/Buell Model: XL1200X "48"
YOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura aboutYOURADHERE has a spectacular aura about
Just use a set of these...They're license plate bolts with a little white LED in them. Pretty clean and will light up your plate as required.
Old 12th June 2012
yep, the led strut lights mount onto the back of the strut plates. They are a 2 wire set up. you just run the wires to the turn signal module that is under the seat. I cut the ends off of my strut plates so I could run the wires more internally. You don't have to cut them though to mount them up.
Old 13th June 2012
darkdesign's Avatar
thanks guys, i can't believe i didn't remember those myself!!
Old 14th June 2012
XLFREAK XLFREAK is offline
Cleaned up the wifes 48, one last mod she wants is the mini apes, which are hangin in the garage waitin on funds for the cables!
