0 Sportster or Street Bob
Last Post: RKN
0 Drive Chain Adjustment
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
Old 21st May 2010
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
Default no more foo foo's at NOSPARTS
Nosparts.com ran out of foo foo valves so I guess it is either the KrankVent, the Doherty, or the Feuling positive vent systems.
anybody use these???? the doherty and the feuling are about 80 bucks on sale right now at dennis kirk, the krankvent is about 100
all for a simple reed valve
Old 21st May 2010
Try Mary at Jims HD: info@jimsharley-davidson.com
Old 22nd May 2010
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Foo foo valves were only used on '77 and '78 model years. Your profile indicates you have earlier Ironheads that have timed breather valves on the oil pumps. A bit confused here....
Eric
Old 22nd May 2010
eric,
C'mon...I've built several of these bikes from cases up....I just got a 77 basket and will build it over summer.....the cases need attention....no foo foo was present in the baskets....the guy said the bike was always oily....no foo foo and blow by will cause this
Old 22nd May 2010
OK, I understand now. The valves do come up on Ebay frequently from one source so you might watch for a little while before committing to another breather style.
Eric
Old 22nd May 2010
There's got to be one laying around a dealer somewhere, gathering dust. Check the parts locator...
Old 22nd May 2010
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Jims Harley Davidson like Mick said is where we got ours. ...i've got a dealer list on my work laptop of who had them in stock a year or so ago. . .can dig it out Monday if your still looking
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 22nd May 2010
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
If all else fails you can machine an aluminium plug with a 5/8" hole in it. The actual flapper valve is made from some 30 -32 guage (~0.010" thick) SS sheet metal with an ear to accept the two small hold down screws.
With an ever so slight bend near the base of the ear the flapper will stay against the plug's hole and yet lift when the crankcase pressure starts to rise.
As I recall some styles of brake calipers have a thin SS shim that sits between the inboard brake pad and the piston - it may be just the ticket for the flapper part.
Cheers;
Old 22nd May 2010
Here's a pic of the foofoo valve that is inside the assembly ...
Old 22nd May 2010
http://www.chicagoharley.com/shop/ad...633-77&x=0&y=0 shows it listed. Whether or not it is in current inventory is entirely another question.
