Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 24th May 2010
MGB MGB is offline
Sportster/Buell Model: 1200 Custom (Wife's)
Sportster/Buell Model #2: 883 (Wifes)
Sportster/Buell Year #2: 2002
Other Motorcycle Model: FLHTCSE (Mine)
MGB is an unknown quantity at this point
Default Inaccurate speedometer
Just got an '04 1200 custom a few weeks ago and just now found out that the speedometer is off about 5 miles per hour. Only about 4000 miles on the bike. Any thoughts???
Old 24th May 2010
Brad's Avatar
Brad Brad is offline
Senior Master Bolter Oner
Mine indicates 65 when I'm doing 61 (confirmed by other bikes and my GPS) I'm just living with it. Figure it can't hurt me.
'05 883 C
Old 24th May 2010
Shaft's Avatar
Shaft Shaft is offline
Shaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the roughShaft is a jewel in the rough
They're all inaccurate... in your car, bike, truck... none perfect. Usually they have a sweet spot where they are most accurate and then fall off after that.
I wouldn't sweat it.
---insert satirical commentary here---
Old 24th May 2010
roachhill roachhill is offline
Other Motorcycle Model: Ducati Monster
Other Motorcycle Year: 1995
roachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud of
That's alot closer than my speedometer. They are only required to be within 5 mph but mine is closer to 10 mph off at highway speeds.
Old 24th May 2010
mozart577's Avatar
mozart577 mozart577 is offline
mozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nice
The '04 and '05 models were notorious for this problem. Some of it can be cured with the current ECM flash, but it still won't be perfect. What brought mine back to accurate was putting a 130 tire on the rear in place of the 150, but mine was only off by 2% after the re-flash.
2005 883 Custom, 16" apes, Arlen Ness Big Sucker, w/EVO 8" round cover, National Cycle light bar, Mustang Wide Studded Solo Seat and Pillion, Khromewerks 2" drag pipe slip-ons, Cycle Visions 30" sissy bar, 3" tank lift, HB125XL Hydraulic Primary Chain Tensioner. Riding is my life. Blinging is just a hobby.
Old 24th May 2010
cotnballs's Avatar
cotnballs cotnballs is offline
cotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nicecotnballs is just really nice
3 mph fast on my 2009, confirmed with GPS and Road side radar trailers.
"For those who care, I do not"
Old 24th May 2010
dashadow's Avatar
dashadow dashadow is offline
Sportster/Buell Model: 883C
dashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant futuredashadow has a brilliant future
The same problem exists for the 2005s. There is an ECM reflash available through the dealer. There was no charge to have it done when I first heard about it in early 2005. I don't know if they would charge for it at this late date. Since the 2004s and 2005s are almost identical I would assume that the same problem exists with the 2004s.
I never bothered to have mine done, I just know that it reads about 10% fast and shows 10% more miles than actually have been covered.
Talk with a local dealer, maybe it will be fixed free.
I'm not into this Twitter thing, I prefer to follow people in person.
Old 24th May 2010
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
The speedo re flash is also supposed to correct a timing issue.
SEMJPM
Old 24th May 2010
bshadbolt's Avatar
bshadbolt bshadbolt is offline
Other Motorcycle Model: Suzuki GSX750ESG
Other Motorcycle Year: 1989
bshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura about
Mine says I'm doing 220kmh while sitting still - the speedo died some time back.
But most speedo's are not accurate, or I should say they are built to indicate within an accepted error range, usually calibrated to read higher than actual to prevent you accidentally speeding. 10% higher than actual is typical.
Cheers,
Brett
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
Old 24th May 2010
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
That's almost exactly what mine is off........as verified by my gps.
Stuff: YES
