0 Feeling in trouble.
Last Post: sdsbassist
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
7 Long Road Trip advice
Last Post: gravydog
Last Post: seanq2208
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
Old 24th May 2010
FriscoJimmy FriscoJimmy is offline
Sportster/Buell Model: 883 Hardtail Project
Sportster/Buell Year: 1986
FriscoJimmy is an unknown quantity at this point
Default Engine Bolts
Hope someone can help me out here...
I have an 86 Evo engine mounted in a Paughco frame it was a mocked up roller when I got it.
Some of the engine bolts slide in and out and/or are to long for the spot they are in and some bolt wont budge at all.
Is there a list of what size/length stock engine bolts are? or a place I can order stock engine mounting bolts?
I tried searching on here..but have had no luck...
thanks
Old 24th May 2010
ol38y's Avatar
ol38y ol38y is offline
Sportster/Buell Model: 1250
Sportster/Buell Model #2: 1350 S+S
Sportster/Buell Year #2: 1995
Other Motorcycle Model: Screaming Eagle Ultra
ol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud of
Have you tried a tape measure and the local hardware store???
When in doubt, gas it...
Ol' Chief Larry of the Dirty Ducks MC
Old 24th May 2010
Wraith's Avatar
Wraith Wraith is offline
Sportster/Buell Model: XLN
Wraith is an unknown quantity at this point
Probably need the factoy parts book.
Old 24th May 2010
Jafa39's Avatar
Jafa39 Jafa39 is offline
Sportster/Buell Model: XLH1100
Jafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enough
The bolts should be about 3/4 of an inch longer than the width of the engine casing boss where the bolt goes through...maybe half an inch at most...when bolted up the end of the bolt is flush with the outside face of its nut.
Shake, rattle and roll...is there any other way to travel??
