Last Post: Vohnsen
Last Post: sltm1
0 What's your helmet?
Last Post: Zoharo
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
0 C.O.B.B run west
0 no rear brake light
0 New England 2018
Last Post: tvon
cam, timing, urgent
Old 28th May 2010
Cory J's Avatar
Cory J Cory J is offline
Sportster/Buell Model: XL883 converted to 1200
Sportster/Buell Year: 2ooo
Cory J is on a distinguished roadCory J is on a distinguished roadCory J is on a distinguished road
Exclamation Very urgent help needed. (Big oops)
I have done something rather stupid. I am polishing the cases and covers on my bike and i took a bunch of them off. I called the nearest harley dealer a few cities over and asked them if there would be oil behind the right side cover of the motors bottom end. They assured me that the rear cover was a belt cover, the front just a cover and there would be no oil. However, there was oil, and also a cam shaft popped out secured inside the cover. When the cam popped the pushrod dropped and now i cant get it back in. Some insight would be much appreciated before i tear into the top end of the motor and try to lift the rocker. Also, how do i know its in there in the correct position? Is there going to be a huge task ahead of me to rebuild it and set timing? Thanks a bunch in advance.
Old 28th May 2010
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
For the Experts to see!
Yeah, you've stepped in it! These guys will take you through this with no problems!!! Good Luck!
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Old 28th May 2010
Cory J's Avatar
Is there a way to put the cam back in without puling the pushrod? I have been looking online and i have foun the procedure for lining up the dots on the shafts. It says to drill the rivets out of the ignition cover with the big #5 on it, do i just rivet it back on after
Old 28th May 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You can either rivet it or use two small screws.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 28th May 2010
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
It is said that experience is the best teacher. If I didn't know what I ws doing taking them off, I damned sure wouldn't trust myself putting them back on. Have your bike trailered somewhere you trust and have a professional reassemble your motor.
If you hate me, I've probably given you just cause. There, feel better?
Old 28th May 2010
DIESEL's Avatar
DIESEL DIESEL is offline
get a gasket kit, factory manual, and follow the directions. I don't know how the push rod came out. It isn't hard to reassemble the top end on these. should take a couple hours.
post some pictures of how it looks before you take anymore shit off the bike.
Old 28th May 2010
floorit's Avatar
floorit floorit is offline
Sportster/Buell Model: 1200c
Other Motorcycle Model: Honda XR250r
Other Motorcycle Year: 90
floorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to behold
Search up Turbota's cam swap thread. It has easy to follow directions, and pics, and will walk you through the proccess. The only way I know of to put the cams back without pulling the rockers is with adjustable pushrods. IMHO, that is just as trouble as pulling the heads.
Old 28th May 2010
DIESEL's Avatar
where you at? Is the pushrod completely out of the bike?
Old 28th May 2010
floorit's Avatar
If people would list at least a general location I bet they would be amazed to find a local member who could help out with problems like this.
Old 28th May 2010
DIESEL's Avatar
You are correct sir..
