5 Transmission HELP!
0 ALIEN Themed 1250
Last Post: Shai`tan
Last Post: MatHormell
Last Post: ezmerf
0 ParrotHead's Mods For My "New" Sporty
0 Ei
0 Sportster or Street Bob
Last Post: Bone
Last Post: hexnut
Last Post: conv90
Last Post: BluBeaSSt
Old 31st May 2010
joestuff's Avatar
joestuff joestuff is offline
Sportster/Buell Model: XLCH, restored
Sportster/Buell Model #2: XLH, period hotrod basket
Sportster/Buell Year #2: 1961
Other Motorcycle Model: FXDXT (T-sport)
Other Motorcycle Year: 2002
joestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the rough
Default kidney oil tank/battery box picts request
Hey all, as most of you don't know, I'm putting a 1974 together. Started with frame and cases. I'm having a bit of trouble figuring out how exactly the battery box/oil tank/ regulator all went together on a stock bike. My parts manual helps a bit, but not enough. No, I'm Not sure if all the frame tabs are on my frame. Anybody got picts of that assembly to help me out.
Thanks
Joe
Gone are the days we stopped to decide, where to go, we just ride...
-Ironhorse of the Hell's Beerguts MC.
Old 31st May 2010
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
The battery tray support leans towards the head bolts to the trans. make sure the bolts aren't too long as the one closest to the out case will interfere with the trans gears. There are 2 rubber isolators on it. One on each side. On accessory block on the left side of the frame above the motor mount (rectangle with square holes in it), place one rubber isolator in the bottom hole. Install negative battery cable to the top hole now, pain to get in later. Install battery tray from the left side onto those 2 rubber isolators. There is a tab on the right side of the battery tray that will be located out by the diagonal brace up towards the seat rail. Install another rubber isolator there. The oil tank has a tab on each side that attaches to those isolators. Then install the three bolts through the end of the battery box. The regulator installs on the battery tray where the studs are sticking out. There are 2 'coves' on each end of the battery tray on the right side. The front 'cove' is for the vent hose that comes out of the cam chest, routes in the recess between the case and rear motor mount and goes to the forward or 'middle' fitting. The 'cove' on the rear is for the battery positive cable to get to the solenoid and for the return line that comes off the top of the trans, under the starter, through the hole in the battery tray support and up to the top fitting by the cap. The supply line is the lowest fitting and routes with the vent line by the motor mount down under the motor to the oil pump.
Life may begin at 30, but it really interesting around 150!
Old 1st June 2010
joestuff's Avatar
thanks. I see now I'm missing the support piece.
