Last Post: Sprtstr1200s
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Lowboy frame conversion
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 1st June 2010
jettech777's Avatar
jettech777 jettech777 is offline
jettech777 is an unknown quantity at this point
Default Primary Adj. Hot or Cold ???
Is it better to adjust the primary chain with the gearbox hot or cold, What do you say?????
"Work Sucks Let's Ride!"
'05 1200C SE Stage1, Rinehart Drag Pipes
Old 1st June 2010
Porky's Avatar
Porky Porky is offline
Sportster/Buell Model: 883 Roadster
Porky is an unknown quantity at this point
COLD. The chain "Grows" as it warms up.
2005 883R, 2009 T-max, 2009 Buell 1125CR, 2010 Triumph scrambler.
Old 1st June 2010
kiwicafesporty's Avatar
kiwicafesporty kiwicafesporty is offline
Sportster/Buell Model: 1200
Other Motorcycle Model: MV Agusta
kiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to beholdkiwicafesporty is a splendid one to behold
Doesn't matter according to the manual. Gives a different length to adjust to for hot or cold.
Old 1st June 2010
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
Actually, can't say about the manual for your 00. but it matters for the OPs 05 (and as I understand for pretty much all the 04+) where the manual specifies to do it overnight cold stating that the factory tools necessary for hot adjustment aren't available in the field.
Old 1st June 2010
Oli1200's Avatar
Oli1200 Oli1200 is offline
Oli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of light
I tightened mine to the point where I could hear it whine while riding with a 3/4 helmet on. Then backed off and loosened it gradually until I couldn't hear it whine while riding.
Old 1st June 2010
flashedwards's Avatar
flashedwards flashedwards is offline
flashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant futureflashedwards has a brilliant future
The owner's manual for my '09 gave specs for hot and cold...
Cold...3/8"-1/2"...9.5mm-12.7mm
Hot....1/4"-3/8"...6.3mm-9.5mm
I hope this helps,
Flash
Trying to balance being an "unknown quantity" and a "known associate" ....it's tuff
2009 XL1200N Nightster...SE Heavy Breather>SE SP black slip-ons w/modified Cycle Shack baffles>Speedway Instruments MicroTach+>Super Brace>Kriss headlight modulator. Willie G skulls @ gas cap,derby and timer>Misc. black nut and bolt covers>Garage Leathers solo bag>Mustang Vintage 12.5" solo seat>LED taillights>10.75" RK air shocks>G2 Ergonomics Quick Turn throttle>Power Commander V>Giving 10R12 plugs a try.
76 HP X 79 TQ
Ol' Dirtbeard of the Cracked Craniums MC
Old 2nd June 2010
jettech777's Avatar
I did it cold, found the tight spot and shot for about 3/8" and it seems to be just fine...
Old 2nd June 2010
mozart577's Avatar
mozart577 mozart577 is offline
mozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nicemozart577 is just really nice
How hot is hot? Since "hot" is a relative term, I've always adjusted mine cold.
2005 883 Custom, 16" apes, Arlen Ness Big Sucker, w/EVO 8" round cover, National Cycle light bar, Mustang Wide Studded Solo Seat and Pillion, Khromewerks 2" drag pipe slip-ons, Cycle Visions 30" sissy bar, 3" tank lift, HB125XL Hydraulic Primary Chain Tensioner. Riding is my life. Blinging is just a hobby.
Old 2nd June 2010
Rainrider Rainrider is offline
Sportster/Buell Model: 1200 roadster
Rainrider is an unknown quantity at this point
I check/ adjust mine when changing the primary oil. Pull drain plug/ inspection cover and let it drain over night, then check and adjust if needed cold. That way there’s less oil mess when I roll it in gear with plugs out to find the tightest spot and adjust if needed. Then after the next ride I do a quick hot check. The chain sure tightens up when hot, and will screw things up if you run like that. That’s how I do it.
Old 3rd June 2010
joe66's Avatar
joe66 joe66 is offline
Other Motorcycle Model: Kawasaki 900Z1B
Other Motorcycle Year: 1976
joe66 is on a distinguished roadjoe66 is on a distinguished roadjoe66 is on a distinguished roadjoe66 is on a distinguished road
Default primary
The way I've always checked or adjusted mine is hot. This is my reasoning. Since hot is the natural, normal operating temp, it just seems best to adjust it then. When is the chain cold? When it's sitting still. When is it most important for the chain to be adjusted correctly? When it's being ridden, in other words, Hot!
I go for a ride to warm things up, Park bike. Jack up bike. Remove inspection cover. Remove drain plug. Adjust chain as oil drains. Replace plug. Add oil and replace cover.
Am I looking at this wrong?
'05 XL1200R
Mustang Daytripper, Hurricane AF, SEII SD, Progressive springs and shocks. Willie & Max large slant bags with Easy Brackets, Iso grips and pegs. Superbrace, Quick detachable windshield. Single driving light.
"The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" - Thomas Jefferson
