Last Post: gravydog
0 Sportster or Street Bob
Last Post: Baby883
Last Post: RKN
0 New member in MD
0 19" to 21" sportster front wheel finally done and installed
0 Rear tire
0 Salutations y'all
0 Overheating after cams and headwork
0 Decman's Birtday
Last Post: O.R. John
5 Transmission HELP!
Last Post: Blowupster
0 Oil??
Old 15th September 2007
Jimbo66 Jimbo66 is offline
Sportster/Buell Model: Ironhead 1000
Sportster/Buell Year: 1972
Jimbo66 has disabled reputation
Default Starter trouble!
I´m from Sweden and i have a 1972 Ironhead with a prestolite starter!
My trouble began about a week ago when the solenoid gave up.
I bought a repair kit and change the plate and the cover, then it worked again..
But after a a few starts the solenoid gave up again, the plate from the repair kit was loose and shorten the solenoid and my new battery
I phoned the company that sold me the repair kit and they send me a new solenoid.
I change the solenoid but i didn´t work, the starter just spinning and the pinion gear don´t move out like it should.
I have checked the cables for shorts and i have a new battery so nothing is wrong there.
One thing i begin to suspect is the pinon gear,when i move it on the axel
it locks up some times on the splines.
But to remove the pinion axel i must remove the clutch shell, so i hope someone can give me a tip.
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
Sounds to me like you are on the right track. When I need a new starter on my 68 I change boots
superwarden: Yeah, it´s better to just change boots than starter
Soon it´s winter here in Sweden and then i´m going to add a Kickstarter axle.
Old 16th September 2007
Yeah some days I wish I had the electric though, when there are lots of witnesses and she won't fire!
