Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 9th June 2010
16ouncePBR's Avatar
16ouncePBR 16ouncePBR is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLR Tribute
Sportster/Buell Year #2: 1962
Other Motorcycle Model: XLH
Other Motorcycle Year: 1968
16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light16ouncePBR is a glorious beacon of light
Default Triple Tree to Frame Lock Loops?
Does anyone know when HD starting adding the padlock loops to the frame and the bottom triple trees?
I have a -52a tree w/o loop and a 66 frame with them. Quite possibly could have been cutoff by the PO, but...
Just curious.
Old 9th June 2010
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant future
The frame had the loop as far back as the k model days. it was originally used to mount the steering damper. i myself am also curious about when they started to add the lock tab to the lower tree. they still used the steering damper in 1966, so the tree wouldn't have had the lock tab. both of my '69 xlch's have the lock tab. so they added it sometime between 1966 and 1969. hopefully someone has the answer because i am restoring a 1967 xlch and need to know if my lower tree needs the lock tab. i suspect it was added sometime in 1967.
Old 10th June 2010
16ouncePBR's Avatar
What an exciting thread....Well maybe not but...
Been scouring the parts books and the 54-65 K/Sportster book shows a -54A tree without. The 54-78 book shows 70 and earlier front end as a separate piece called "Fork Lock Bracket" with part number of 45724-68A. Seems as if it is a bolt or weld on piece. The 71-72 front end shows that too. As well as the 73-74 too. Plus the 75 up.
Think Magneto Sportster is pretty close with 67 or 68 being the year based on the part number ending in 68A.
So in summary the my 62 project is proper without.
Not sure why the 69s have it for security...They already have a Tillotson.
Old 10th June 2010
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant futureMoon Wolf has a brilliant future
Yes, that's the correct triple tree for your bike. Magneto, I will go look at my 68 and see if the triple tree has the lock tab as soon as this freakin' rain stops! (It's been raining here for about a month and a half).
Old 22nd August 2017
kmul kmul is offline
Sportster/Buell Model: xlx
Other Motorcycle Model: FLHR, BD Vintage, 59 XLH
Other Motorcycle Year: 1998
kmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to beholdkmul is a splendid one to behold
was just looking on ebay for a nos 45724-68A fork bracket but no joy. guess I will cut one off a an old -52A tree I have that is already butchered by someone else. would rather have the lock tab than the dampner.
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHTK
Other Motorcycle Year: 2010
sleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the roughsleighcrane is a jewel in the rough
I was curious as well because I don't have one on the tree either. Does it attach to the small hole somehow?.
no. it is a weld on tab. look at a later year tree and you will see it. the -78b parts catalog shows it. do an ebay search for lower triple tree and you will find a picture of one on the tree. the lock goes through the tab welded to lower tree and then through the loop on frame where the steering dampner would have gone. later 33.4 and then the 35mm trees have them until maybe 79-82. don't know where they changed it. I'm guessing they sold the part separately so that earlier bikes could be retrofitted.
Old 23rd August 2017
MXHD55U MXHD55U is offline
MXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant future
the 67's in my shed has one. 62 XLH doesn't and the 64 XLCH basket doesn't.
I know of a 66 XLCH in my hood so I'll try to catch up with it's owner tomorrow.
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Yeah, who WOULD steal a bike with a Tilly ?
Old 24th August 2017
Now that's funny right there
