0 XL Bomber - Portuguese project
Last Post: d10221
0 Dellorto PHM38 Parts Sources - Intake Rubber, Throttle Cable
Last Post: nakina
0 Setting Timing, 1964 & Earlier Mag
0 Ironhead engine problem?
0 900 clutch in a 1000 engine Strociek
0 72 ih stroker advise needed
Last Post: toe
Last Post: toe
0 NOS cases
Last Post: DR DICK
0 Strociek Project Help Needed
0 WTB S&S super B parts
Last Post: bretton
0 Another question re: Microsquirt
Last Post: gl90hog
0 North central Mass
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (EFIs)
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
3 Wtb, Wts, Wtt, Wtg (Evos)
0 BEWARE Of SCAMMERS!
0 Showa 54000088 Shocks
Last Post: d10221
0 1100 bathtub heads on a 883?
Last Post: JimVonBaden
Old 13th June 2010
rocketmangb's Avatar
I drug mine Bro !
Evidently i have inch short Progressives though !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 13th June 2010
DBH's Avatar
DBH DBH is offline
Sportster/Buell Model: 883/1250 Sportster
Sportster/Buell Year: 03
Sportster/Buell Year #2: 1977
Other Motorcycle Year: '02
DBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond repute
Here is how I did mine, it worked good with my forwards, but won't work with your mids. I still need to make some new mounts for the passenger pegs that mount to the swing arm.
http://xlforum.net/forums/s...d.php?t=763041
Life should NOT be a journey to the grave with the intention of arriveing safely in an attractive well preserved body, but rather slideing in sideways, "Jack" in one hand and a beer in the other, body thoroughly used up, totally worn out, screamin "Holy shit what a ride!"
Life is all about "Faster horses, Younger Women, Older Whiskey, And more Money" Thank you, Tom T Hall
“A free people ought not only be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them. Which would include their own government.”
– George Washington
Old 13th June 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I studied yours. You did a great job.
How you liking them now that you're getting used to them?
Old 13th June 2010
biknut's Avatar
After a few hours of thinking my brain started farting up a brain storm. I tore it up a little after that. This is what I'm thinking now.
What do you think? Here, or should I try to lift it up a little more? It's kind of hard to tell from this picture but the m/c is more under the pipe than it is behind it.
Old 13th June 2010
Watch the size on the master !
Hydraulics get weird !
If you go smaller it needs more stroke and less pressure to apply
Bigger is less stroke and more pressure
Old 14th June 2010
DBH's Avatar
DBH DBH is offline
I love mine, they have stayed tight with no leaks. I need to tune the bike a little different now, not sure what it needs. Trying to decide which way I need to go, hard to tell, it runs fine just different than the SE's.
Old 14th June 2010
biknut's Avatar
This one is 1/2"
I think my stock one is 9/16", so I'm going from 9/16" to 8/16". I'll just have to keep my fingers crossed on that one.
Old 14th June 2010
8/16"
Lemmee get my slide rule.
Ok i got it
more push and less pressure on the pedal
If you go to a 49.5 pilot jet it will negate that !
Old 14th June 2010
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond repute
A couple questions.
What is the measured width between the mount with the support bracket and the pipe? What is the measured width at the fattest part of the M/C?
You should be able to run that M/C in either position without issue. You will only need 1/4 to 3/8 clearance between the M/C and the pipe if you want to hide it behind the pipe. Do you plan to run the reservoir in the starter area with a line down to the M/C? There should be enough room to run the line behind the back of the motor between the mount and frame
Old 14th June 2010
biknut's Avatar
Originally Posted by cycowrencher View Post
A couple questions.
There's only a little over 1/2" between the stock m/c mount, and the back of the pipe. The widest part of the new m/c is 1 1/8". The plate I'm going to use for the new mount takes up an additional 1/4". It looks like the m/c will need to be under the pipe because of this. I don't know where I'll mount the reservoir yet, but will be up above somewhere.
