Last Post: Moon Wolf
Last Post: kaveebee
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: Beelzeboss
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Last Post: maltesefalcon
Old 14th June 2010
Gone Gone is offline
Exclamation Sportster battery keeps dying (what's up)
My 2009 XL1200C has been perfect since I got it. Now for the first time I rode it 3 days in a row to work in straight rain.
The 4th day I went out to ride to work (no rain), I went out to start the bike and dead battery (not even any lights or anything). Put on a trickle charge overnight and bike starts up and ride around for an hour. Bike will start up right away after bike is shut off so I'm thinking it's kept it's charge.
Next morning dead again. Any suggestions. I have an HD security system on it and instead of the usual pulsating key light, it's on a steady bright red after I turn off the bike. I also notice I now don't always get that sound of the Fuel Injector before start up. Weird...
I'm thinking something is running after I turn off the bike but can't put my finger on it. Did the ride in the rain cause this?
Please help.
Thanks,
Silver
PS - I didn't take out the key on ACC it was completely off.
Old 14th June 2010
snowman's Avatar
snowman snowman is offline
Check the cable ground connections...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 14th June 2010
joesporty's Avatar
joesporty joesporty is offline
Sportster/Buell Model: xl 883
Other Motorcycle Model: kz750
Other Motorcycle Year: 1976
joesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant future
and all the fuses...
SMOKEY BURNOUT MASTER OF THE WORLD!!!!!
08 XL883;HAMMER 1250,Heavy breather,Rinehart 2-1, Power Vision,Ebc floating rotor,XR1200 Nissin caliper,1200R Mastery cylinder,RK shocks,1in tank lift,wire tuck,crossroads fork brace,low rise drag bars int.wired,Goodridge Ss line,Chrome valve stem covers, and a few top secret parts..:smoke
Old 14th June 2010
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Check the all the battery connections and fuses (as the others mentioned). Also, pull the relays and see if there is any corrosion. It's a well known issue with the EFI bikes that they goofed with the wiring harness and the relays often get corroded. There's a few different symptoms, one of them being battery dying because the corrosion allows the battery to drain.
Do you have a voltmeter (and know how to take volt readings)? It's pretty easy to check if the charging system is working.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 14th June 2010
PaulDM PaulDM is offline
Sportster/Buell Model: XL 883
PaulDM has disabled reputation
I had the same symptoms, dead battery after sitting overnight. In diagnosing the electrical drain I noticed that the efi pump was slowly running. I replaced the relay and it's been fine since. Last week the bike didn't want to start, it felt like a problem with the switch itself, I broke out my spare relay and installed it and that problem went away too.
2007 XL 883 - 1/4 Harley Fairing - ISO grips and pegs - Mustang Vintage wide - Adjure Reflector & PIAA bulb - 50 State Mufflers - ABS front fender - Tail pack for stuff - HyperPro progressive fork springs - Whittlebeast rear shocks = Rocky Mountain Sport Tourer :-)
Old 15th June 2010
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
Yup to what Dan said - I seem to remember some threads about corroded relays allowing the IAC valve to constantly cycle with the key off which would slowly drain the battery.
Old 15th June 2010
LuxBlue's Avatar
LuxBlue LuxBlue is offline
+ 1 on everything said here. Your riding in the rain and / or washing has corroded your relay terminals resulting in your fuel pump probably running all the time. Easy fix to clean the corrosion and I would recommend spraying the back side of the board with a conformal coating of some sort.
Old 15th June 2010
Bone's Avatar
FWIW Lux, I've never heard of/seen the fuel pump run because of the relays...because I'm pretty sure it takes the ECM to complete that circuit, but it's same idea, some components of the EFI system are cycling when the relay clicks shut... I guess in theory the fuel pump might cycle too then I dunno
Old 15th June 2010
LuxBlue's Avatar
Could be? What I should have said is corrosion is causing some kind of sneak path on the relay board making some component run and drain the battery.
Old 15th June 2010
crospo's Avatar
crospo crospo is offline
Sportster/Buell Model: 04 XL1200R
Other Motorcycle Model: Yamaha Seca400
Other Motorcycle Year: 1982
crospo has disabled reputation
Pull the main 30Amp fuse overnight.If battery is still fully charged at least you know there's a drain somewhere.Then you can likely rule out the battery and charging system.
