0 New member in MD
Last Post: Veeflys
0 Primary Oil INSANITY!
0 Newbie CV rebuild
Last Post: Matt Black
0 Ei
Last Post: cazz1000
0 Decman's Birtday
0 Turn signals
Last Post: bockstroker
Last Post: r4fthrs
0 Oil??
0 acc pump
Last Post: Armand
Old 17th September 2007
shotyme1 shotyme1 is offline
Sportster/Buell Model: 1200xlc
shotyme1 is an unknown quantity at this point
Angry any way a 05 & up rear wheel to fit a 04
I was wondering if anyone ever put 05 or newer wheels on a 04 1200 xl custom? I purchased an 06 wheel set 13 spoke cast and now notice the rear axle looks different. Are the rims the same with different bearings? I needed a rear rim due to peeling bad and warranty over when I started to notice.
Wheezy's Avatar
Wheezy Wheezy is offline
Wheezy is on a distinguished roadWheezy is on a distinguished roadWheezy is on a distinguished roadWheezy is on a distinguished roadWheezy is on a distinguished road
You''ll need to either a 1 inch axle, or to have a 3/4" bearing pressed into the wheel.
~Wheezy~
Jt1200r Jt1200r is offline
Sportster/Buell Model: 1200r
Jt1200r has disabled reputation
swingarm ,axle ,and bearings. 05 and up use 1" axle
so if i get 3/4 bearings pressed in the 06 wheel and use my axle ,spacers , swing arm I should be ok?
