0 New in NM
Last Post: _Outlaw
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Tank swap
Last Post: Grymy
0 FNG from OKC
0 Lowboy frame conversion
Last Post: spacecoast
0 Primary Oil INSANITY!
0 What jets do you use?
Last Post: David L.
Last Post: David L.
0 Show your tank decals
Last Post: Tonail
Old 15th December 2004
x750rider x750rider is offline
x750rider has disabled reputation
Default Do I HAVE to winterize?
I live in Virginia where the winters can get harsh but at the same time you might have a 45-55 degree day thats good enough to get a little saddle time in. So my question is this:I keep my 2004 1200c covered in a shed w/no heat but is there any reason(sane) that I just coundn't start my bike at least once a week and bring it to operating temp. for say 5 mins? Wouldn't this keep the engine lubed well enough & the batt. charged? I have a Mitzubishi 3000gt that I basically have done the same thing to for several years w/no problem. Anybody got any feedback on this? I sure would like to keep her ready to roll just in case I get that itch.
GregD's Avatar
GregD GregD is offline
Sportster/Buell Model: FLHTK
GregD is on a distinguished roadGregD is on a distinguished road
I would suggest that you put the battery on a tender, stabilizer in the gas tank and when the occasional day arrives take it out for a run.
Just starting it for 5 minutes or so once a week is probably not the way to go because the engine doesn't get hot enough to evaporated the condensation that can accumulate. It can even add to the problem of condensation.
The engine needs to get to operating temperature to dispell the condensation and just letting it idle won't do the trick.
This is JMHO. I'm sure the pros here can give you the skinny on what is truly proper.
Ride Safe.
Greg....
xena's Avatar
xena xena is offline
Assistant Administrator
My bike is in a non-heated garage and for years I've done it the way you're talking about and have never had any problems other than the spark plugs get a little dirty. No biggy I just clean them up and put them back in. Don't see any reason why I can't do the same with the sporty as I've done with my previous bikes.
I did take a chilly ride around the block today (30F temps) since there's no snow on the ground. I usually put a little of that fuel fresh stuff in the tank too.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Broncodog's Avatar
Broncodog Broncodog is offline
Master Bike Builder
Sportster/Buell Year: 04
Broncodog is on a distinguished roadBroncodog is on a distinguished road
To the forum x750rider! Back in the ole NY days, did same thing but just ran it longer and the occasional ride didn't hurt either
Artie
Secretary
Humpers MC
Orange County Chapter
toothygrin's Avatar
toothygrin toothygrin is offline
Sportster/Buell Model: xl883
toothygrin is an unknown quantity at this point
I've been thinkin the same. here in the Northwest it rarely snows- so I have been doing some short (wet) rides on the weekends. Enjoy
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
Yeah, years ago, way back when, we stored our bikes the same way but times are changing. The problem is that today's gas formulas will begin to gum things up in about three weeks. I'd be sure to keep the tank full and add some kind of stabilizer. Running it once or twice a week isn't a bad idea in any case. Just be sure to bring it up to operating temp if you can't ride it.
What anyone else thinks of me is none of my business.
collinsb's Avatar
collinsb collinsb is offline
Sportster/Buell Model: Custom 1200
collinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura about
X750rider,
I have a differing opinion!
If your bike is kept in any non heated shelter (especially a metal shed) that flutuates in temperature from below freezing to above freezing you will run the risk of your bike sweating. It is best not to "drape" cover it, but if you must, only use a couple old bed sheets, to keep the dust off and air in. Definitely, do not use a rain cover. The metal must breath to stay dry.
I'm of the opinion that starting cold bikes and running them for short periods to "keep them oiled" is a grave mistake. If your going to take a 1/2 hour or more ride, that's a different story. A short run cold engine can become full of moisture. Running it for 15 min., or just operating temps is not IMHO enough to dry it out sufficiently!
Billy Norust
Oh Yeah!
My motorbike is better than your motorbike!
My dad can beat up you dad!
Yo momma!
MisterB's Avatar
MisterB MisterB is offline
MisterB has disabled reputation
My Harley dealer told me that unless the engine is running at a constant speed of at least 3,000 rpm's, that the battery is actually being drained. In other words, even if you start your bike every few weeks, you're actually chipping away at your battery every single time you do it. You'll need to put a battery tender on it, if you plan on actually being able to start and ride the bike when the feeling hits.
Moved On Moved On is offline
I have to agree with Greg and Billy on the two issues they each raised.
My dealer recommend not to start the bike up unless I plan on running it for an hour or so. As soon as you start the bike water vapor is going to get sucked into the crank case and mix with the oil. Unless you get it hot enough to vaporize (dealer said that would take about an hour) the water will condense and accumulate in the bearings. He said that it wouldn't cause any immediate problems but could easily make a difference whether you get beyond 100K miles or not.
The cover isn't a good idea in the cold because the little bit of moisture in the air will come in and condense on the bike everytime you open the door to the shed. With the cover on the bike it will be less able to evaporate back off. My dealer actually recommended that anyone keeping their bike in a cold garage spray down all the exposed metal surfaces with WD40 or Mazola cooking spray to prevent water vapror from condensing on the surfaces.
Gary
Broncodog's Avatar
Master Bike Builder
"My dealer actually recommended that anyone keeping their bike in a cold garage spray down all the exposed metal surfaces with WD40 or Mazola cooking spray to prevent water vapror from condensing on the surfaces."
Have you ever tried that!? Sounds good in theory, but boy could that get messy.
