Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 30th June 2010
brekin's Avatar
brekin brekin is offline
Sportster/Buell Model: 883r
Sportster/Buell Year: 02
brekin is an unknown quantity at this point
Default storz high pipes on 02 883r
I'd like to put some high pipes on a pre -04 883 / anyone have bub/storz setup on one ? I heard it might not be a lot of mods to put them on / they are made up with mounting brkts for rubber mount / any ideas or pictures / I have been looking at jemco and omar but the storz pipes look very good / nicer than supertrapps too
Old 30th June 2010
J.P.'s Avatar
J.P. J.P. is offline
Cafe Street Tracker
Sportster/Buell Model: 883/1250 NRHS
Sportster/Buell Model #2: 883c (Wife's)
J.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to all
no need to mod rubber mount pipes. there are plenty of high pipes for solid mounts from Storz and others.
2008 XL 883/NRHS 1250, [B]94 HP and 81.5 torque[/B]: Stage 2 heads, Flat top ceramic coated pistons, 536 cams, 10.5:1 compression, Progressive 14.25" 412's, Progressive fork springs, Intiminators, Screaming Eagle Heavy Breather, Custom headers by Justin at Bishop's Custom Cycles with a Dan Moto carbon fiber can, Storz Performance Tail Section, Chainsikle rear sets, Superbrace Fork Brace, Daytona Steering Damper, Jagg oil cooler, Flanders Low Cafe Bars, RSD 1 1/2" risers, 8" Headlight, National Cycles F-16 wind screen, Bar end mirrors, Sport front fender, Honda GB250 tank knee pads
Old 30th June 2010
Bobo's Avatar
Bobo Bobo is offline
Sportster/Buell Model #2: X1
Sportster/Buell Year #2: 1999
Bobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura about
Here is the Storz price list and it appears they only have exhaust for 04+ and the XR: http://www.storzperf.com/pricelist.pdf.
This is from the current SuperTrapp catalog. SuperTrapp and Storz are the only high pipes I am aware of:
Sportster XLH 883/1100/1200 ‘86-99 Satin Stainless / Straight 825-70883 $569.00R
XLH 883/1100/1200 ‘86-99 Polished Stainless / Straight 826-70884 $649.00R
XLH 883/1100/1200 ‘86-99 Satin Stainless / Straight 815-70883 $859.00
XL 883/1200 ‘04-10 Satin Stainless / Straight 815-71202 $859.00
XR 1200 ‘08-10 Satin Stainless / Straight 815-71210 $985.00
From this, I am thinking there are not high pipes for pre-04.
If that is the case, the mount for the Storz, don't know about the mount for the SuperTrapp, mounts to the trans case. I am thinking you would have to take that mount and modify it to have it bolt to your frame. I don't think it would be too difficult but it would surely require some cutting and welding.
Old 30th June 2010
Bobo's Avatar
If look at this page I see SuperTrapp high pipes on a pre rubber mount at the bottom: http://www.sportster.org/tech/exhaust-gc/.
And here some on ebay for 86-99: http://cgi.ebay.com/ebaymotors/SUPER...Q5fAccessories.
Personally, I would go with stainless pipes over the Storz mild metal. I would have for mine but the super trapps comes down two low and would interfere with my rearsets.
Old 30th June 2010
J.P.'s Avatar
Cafe Street Tracker
Weren't the solid mount Storz pipes made by Supertrapp? I think they stopped carrying them when they teamed up with Bub.
Old 30th June 2010
Bobo's Avatar
May be. I don't know. But, I think you are right. If you look in the Storz catalog they don't have any pipes but you can find a picture that shows a part of the exhuast and they sure look like SuperTrapp.
Old 30th June 2010
Weber Weber is offline
Weber has disabled reputation
I'm not sure what the confusion here is about. Storz/BUB and Supertrapp are two completely different companies. Also the first three out of five listings above from the Supertrapp catalog are for pre rubbermount.....which is what you are looking for isn't it?
Old 30th June 2010
Also, I have seen pre-04 Storz pipes pop up on eBay from time to time, so keep an eye open if that is what you have your heart set on.
Old 30th June 2010
Bobo's Avatar
We know they are different. What JP was saying is that Storz has someone else make the pipes. Initially it was SuperTrapp then he went with Bub.
What I meant was they did not show 00-03.
Old 30th June 2010
Bobo's Avatar
Yep, I put a link up here in the thread for him.
