Last Post: Diogenes415
0 ‘68 XLCH...transmission
0 Hydraulic conversion for wet clutch
Last Post: yoshi
0 Re 1986 ignition
Last Post: Flam
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: JacksBrother
0 Sportsterpedia Progress
0 Timing issue
0 Need a source for Ironhead shocks
0 It's a Buyinhead
0 Push Rod Adjustment
Last Post: jammantoo
0 Laconia Motorcycle Rally 2018
Last Post: The Crusher
Last Post: wongjohnson
0 Galled front piston
0 Sportster security help
0 attn DR DICK
0 C.O.B.B run west
0 what tool do you use for this starter bendix screw
5 1979 Sportster XLS Problems
0 Putting a 4.5 tank on my Roadster, but I still want it to look like a Roadster.
Last Post: gravydog
0 Timing after dynatek 2000i install
Last Post: jordan1200
0 Steering Damper Installed (Pics and Review)
Last Post: frankv2
Last Post: lugster
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
Old 23rd September 2007
blacksmith.jb's Avatar
blacksmith.jb blacksmith.jb is offline
Sportster/Buell Year: 70's
Other Motorcycle Model: Virago 250
blacksmith.jb is an unknown quantity at this point
Default Engine pinging when idling
Hi you all
When I start my bike in the morning I do it with a bit of choke on, and it goes in a fast idle about half a minute or so, but I'm thinking that there's some pinging goin on at this RPM. I've read that detonation is supost to happen when you pushing on the engine, like up the hill or something like that. Could it just be the thermal shock on the exhausts? How can I be sure that is detonation?
And if it is.. how do I stop it? I've read a lot about detonation but couldn't find a way to stop it.
Thanks in advanced
For those about to rock I salute you!
I think the det'n is caused either by a lean condition or timing too advanced. I might be wrong on this as i am not expert or have a lot of experience with it.
I would wait for other opinions first, but consider reviewing the Setting Your Pilot Screw and Setting Ignition Timing Stickys.
Old 24th September 2007
whittlebeast's Avatar
Other Motorcycle Year: 2008
Could your motor be stuck at full advance? Detonation at idle is very rare if not imposible. Most likely you are hearing something else.
AW
