Last Post: jordan1200
Last Post: conv90
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Old 8th July 2010
markv460 markv460 is offline
Sportster/Buell Model: xl
Sportster/Buell Year: 1969
markv460 is an unknown quantity at this point
Default something ain't right
A quick run down: I bought a '69 Sportster that had a rebuilt motor and trans(local), and the reciepts to prove it. I talked to the rebuilder and bought the bike. The bike had a broken clutch cable when I bought it so I took it home and threw a clutch cable in it. The previous owner told me that it had a wet clutch and the clutch was grabby till it warmed up. No problem with that, but the clutch also slipped now and then. Pulled the primary cover off and loosened the springs up a bit. Seemed to make a difference, but it was probabley in my head. I'd adjusted the clutch about 4 times and decided to take it apart. The clutch plates and discs look new. The clutch shell, though, wobbles. When I say it wobbles, I mean if if you put your left hand and right hand on either side of it you can shake it at least an eighth of an inch front to back. This can't be right, since the torque from the crank is transfered to this through the primary chain! The clutch hub is tight, which should keep the clutch shell tight. Am I missing something? Thank you guys in advance, this is the place that I learned how to adjust the clutch.
Old 9th July 2010
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
The wobble is normal, I changed out my bearing just to be on the safe side and guess what, Still wobbles!! Pretty goofy design in my opinion, but I guess it worked for 30 Yrs.
