0 Diagnostic help
Last Post: cotton1
0 headight housing
Last Post: Len PA
Last Post: MatHormell
0 Hope Cove, 20th May 2018
Last Post: Gamble Gold
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
Last Post: 83XLX
Last Post: lugster
0 The country store
Last Post: lugster
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
Old 22nd June 2005
yogurtslinger yogurtslinger is offline
Sportster/Buell Model: XL883L
yogurtslinger is an unknown quantity at this point
Default BOBBER PROJECT, How big of a rear tire can I fit???
Hey guys, I am in the middle of my sportster/bobber project and now comes the next step.. I have cut the fender struts off directly behind the top shock mount and have also removed the fender. The new fender will be swingarm mounted once I figure out tires and wheels. I have the bone stock cast 13spoke wheels and tires and want to know how much bigger of a tire wheel combo I can go on the front and back, I also removed the front fender and will be using stock forks/trees.. Can I fit a 140 tire? can I go bigger than 140?? If I have to space out the rear sprocket, I would do it if its not really expensive to do..
so how wide can I go for front and rear tires and rims?
Old 23rd June 2005
bump
Old 24th June 2005
sunkenloot's Avatar
sunkenloot sunkenloot is offline
Sportster/Buell Model: 883R
sunkenloot has disabled reputation
Im working on putting a 150 metz on mine (2002 883) right now..I think if you want to go that big your going to need a chain drive, and offset the front and read sprocket or use a dished rear sprocket. I am having a tough time gettin it to all fit but, it looks like its going to work. You might try and track down some of RottenRalphs posts. He talks about using a 150 with belt drive. Damn cool. Crim and some of the other guys have documented this alot on the sporster.org list as well..He has alot of good info in his posts. There are tidbits of good info thru-out the board here and over there, ya just gotta hunt em down..Like what Im doing right now..
2002 XL883R................................... Stage 1, SE/AC, SE can, Tach/Speedo relocated onto dropped eyebrow, Chain conversion with PBI aluminum flat face rear sprocket, Zippers offset front sprocket for A 50/21 (2.38:1 lower than stock 883 ratio) RK 530 x 112 link nickel plated O-ring chain, Rear sprocket spacer.300, ME880 100/90H19 Front Tire, Metzeler ME880 150/80HB16 rear tire, Black center mags, SE Fork brace, Dyna fork caps, Barnett clutch cable, EZ-pull clutch insert, Pingel Petcock, retro grips, Black slotted levers, HD temp. dipstick, Mini bullet rear signals, no chain guard...................................S.Y.W.F.T
Old 24th June 2005
let the hunt begin
Old 25th June 2006
McJohn McJohn is offline
Sportster/Buell Model: xl883 custom
McJohn has disabled reputation
are you going to custom build the swingarm mount fender? if not, where can you buy this? i'd like the same but cannot find it and am not mechanical enough to build it myself.....
Old 25th June 2006
Gone Gone is offline
uquackmeup wrote this article, supported by rottenralph. Although the article is about mounting the 150/80-16 on the '95 sporty, I found it correct when I did the same on my 2000 sporty. Bought the 3/8 spacer mentioned in the article and it worked perfect with my belt drive. Had to leave the brake pads out of the caliper; once I got the wheel onto the axle, just slipped them in.
http://www.geocities.com/when_pigs_fly_mc/880.html.htm
Best of luck (sorry it doesn't answer the question for yogurtslinger).
Old 25th June 2006
rottenralph's Avatar
MIne is a 93 with the same wide tire. They can run about 6 1/4th mounted and still fit. Need to read the article twice before starting. When done right you will have minimal belt clearance but all you need is a little.
